この手順で使用する道具:
Spudger
$3.99
購入する
Using a Spudger , push both right and left metal clip to release one of the RAM module.
Slide out the RAM module.
Do the same with the second RAM module if necessary.
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
For Keyboard removing, remove all 4 screws.
The one short screw paterns to uper left screw hole directly on the PCB.
Use a Plastic Opening Tools to release the top cover.
Start from the left side.
Go around on the bottom
Finish with the right side.
The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
この手順で使用する道具:
Spudger
$3.99
購入する
Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
Now you can remove the top cover
Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
Remove the keyboard 4 screws on the bottom.
Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
この手順で使用する道具:
Spudger
$3.99
購入する
At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
この手順で使用する道具:
Spudger
$3.99
購入する
Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
Now you can remove the keyboard.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
