メインコンテンツにスキップ
Asus Eee PC 1215N Hard Drive Replacement
必要な工具と部品
  1. Asus Eee PC 1215N Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Asus Eee PC 1215N Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
    While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
    Tolidano - 返信
    Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
    Andrea Borgia - 返信
  2. Asus Eee PC 1215N Hard Drive Replacement, RAM: 手順 2、 3の画像 1 Asus Eee PC 1215N Hard Drive Replacement, RAM: 手順 2、 3の画像 2 Asus Eee PC 1215N Hard Drive Replacement, RAM: 手順 2、 3の画像 3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Hard Drive Replacement: 手順 3、 1の画像 1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Hard Drive Replacement: 手順 4、 2の画像 1 Asus Eee PC 1215N Hard Drive Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Hard Drive Replacement, Top Cover (Touchpad): 手順 5、 1の画像 1
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Hard Drive Replacement: 手順 6、 3の画像 1 Asus Eee PC 1215N Hard Drive Replacement: 手順 6、 3の画像 2 Asus Eee PC 1215N Hard Drive Replacement: 手順 6、 3の画像 3
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
    excellent guide. but be careful - it's very easy to broke narrow plastic clip :(
    Marcin Dudek - 返信
  7. Asus Eee PC 1215N Hard Drive Replacement: 手順 7、 2の画像 1 Asus Eee PC 1215N Hard Drive Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  8. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: 手順 8、 3の画像 1 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: 手順 8、 3の画像 2 Asus Eee PC 1215N Hard Drive Replacement, Keyboard: 手順 8、 3の画像 3
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
    There are two very small screws inside the battery compartment which hold the top edge of the keyboard. These must also be removed.
    Ray James - 返信
  9. Asus Eee PC 1215N Hard Drive Replacement: 手順 9、 1の画像 1
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
    Information : you have 2 screws under battery hole which need to be removed too before to release keyboard
    renard - 返信
  10. Asus Eee PC 1215N Hard Drive Replacement: 手順 10、 2の画像 1 Asus Eee PC 1215N Hard Drive Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    Spudger
    $3.99
    購入する
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
  11. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: 手順 11、 3の画像 1 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: 手順 11、 3の画像 2 Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: 手順 11、 3の画像 3
    • Peel off the protective tape at the bottom left corner.
    • Peel off the warranty void at the bottom right corner and remove the screw below.
    • Remove the 6 other screws.
  12. Asus Eee PC 1215N Hard Drive Replacement: 手順 12、 2の画像 1 Asus Eee PC 1215N Hard Drive Replacement: 手順 12、 2の画像 2
    • Remove the protector plate.
  13. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: 手順 13、 3の画像 1 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: 手順 13、 3の画像 2 Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: 手順 13、 3の画像 3
    • Remove the four Phillips #00 screws from the hard drive caddy.
    • Peel off any tape covering the hard drive, there is no need to remove it entirely.
  14. Asus Eee PC 1215N Hard Drive Replacement: 手順 14、 3の画像 1 Asus Eee PC 1215N Hard Drive Replacement: 手順 14、 3の画像 2 Asus Eee PC 1215N Hard Drive Replacement: 手順 14、 3の画像 3
    • Unplug the hard drive by sliding it to the right, toward the USB ports.
    • Remove the hard drive.
終わりに
25 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Gaetan
メンバー登録日: 12/26/12
9,574 ポイント
18のガイドは作成済み
7 件のコメント
I've just upgraded my 1215N HDD using this guide. This is very good step by step guide. A WIndows 10 Pro install managed to wreck the pre-installed HDD.
Like Tolidano , I just used a normal flat head screwdriver and a Philips screwdriver to carry out the HDD swap. I'm now in the process of installing Windows 10 Pro on to the new HDD.
Richard Bijster - 返信
Very good guide! I my case i need to remove 2 screws from the battery compartment to remove the keyboard
gus - 返信
I also had to remove the two (tiny, but phillips #00) screws from the battery compartment.
I actually went further and removed the motherboard to clean the fan. It wasn't too hard thanks to your guide!
Franciozzy - 返信
I, too had to remove the battery compartment screws. Other than that, and that I couldn’t get the keyboard cable out, the replacement went flawlessly.
Guy, Just Some -
Great stuff, swapped original HD for an SSD. Thank you for this!
Steven - 返信
Great guide, swapped original HD for an SSD on this eee pc today. Worked like a charm.
Thank you for these instructions.
Steven - 返信
Work fine!
I just change the HDD with a new SSD of my 1215B laptop.
15 minutes is a little optimistic, 1 hour for newbies.
Thanks
Corentin - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 39
今までの合計 15,832
