メインコンテンツにスキップ
Asus Eee PC 1201N Hard Drive Replacement
必要な工具と部品
  1. Asus Eee PC 1201N Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Hard Drive Replacement: 手順 2、 1の画像 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Hard Drive Replacement: 手順 3、 1の画像 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Hard Drive Replacement, Keyboard: 手順 4、 2の画像 1 Asus Eee PC 1201N Hard Drive Replacement, Keyboard: 手順 4、 2の画像 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Hard Drive Replacement: 手順 5、 2の画像 1 Asus Eee PC 1201N Hard Drive Replacement: 手順 5、 2の画像 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Hard Drive Replacement, Hard Drive: 手順 6、 1の画像 1
    • Turn the netbook over and remove the eight 6.5mm screws using the J0 Phillips head screwdriver.
  7. Asus Eee PC 1201N Hard Drive Replacement: 手順 7、 2の画像 1 Asus Eee PC 1201N Hard Drive Replacement: 手順 7、 2の画像 2
    • Turn the netbook back over and remove the ten 4.5mm screws using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Hard Drive Replacement: 手順 8、 1の画像 1
    • Flip up the retaining flap on the ZIF connector. Then, pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Hard Drive Replacement: 手順 9、 1の画像 1
    • Remove the four 4.6mm screws with the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Hard Drive Replacement: 手順 10、 2の画像 1 Asus Eee PC 1201N Hard Drive Replacement: 手順 10、 2の画像 2
    • Slide the hard drive to the right and then lift it straight out of the netbook.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Trae Mikesell
メンバー登録日: 10/04/16
394 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016人のメンバー
USFT-NANCE-F16S2G3
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 13
今までの合計 3,480
