メインコンテンツにスキップ
Asus Eee PC 1201N Cooling fan replacement
必要な工具と部品
  1. Asus Eee PC 1201N Cooling fan replacement, Battery: 手順 1、 1の画像 1
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Cooling fan replacement: 手順 2、 1の画像 1
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Cooling fan replacement: 手順 3、 1の画像 1
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Cooling fan replacement, Keyboard: 手順 4、 2の画像 1 Asus Eee PC 1201N Cooling fan replacement, Keyboard: 手順 4、 2の画像 2
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Cooling fan replacement: 手順 5、 2の画像 1 Asus Eee PC 1201N Cooling fan replacement: 手順 5、 2の画像 2
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Cooling fan replacement, Cooling fan: 手順 6、 1の画像 1
    • Remove the eight 6.5mm screws using the J0 Phillips head screwdriver from back of the netbook.
  7. Asus Eee PC 1201N Cooling fan replacement: 手順 7、 2の画像 1 Asus Eee PC 1201N Cooling fan replacement: 手順 7、 2の画像 2
    • Remove the ten 4.5 mm screws from cover plate using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Cooling fan replacement: 手順 8、 1の画像 1
    • Pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Cooling fan replacement: 手順 9、 1の画像 1
    • Remove the two 4.6 mm screws from the cover plate using the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Cooling fan replacement: 手順 10、 1の画像 1
    • Unplug the connector.
  11. Asus Eee PC 1201N Cooling fan replacement: 手順 11、 1の画像 1
    • Lift up and remove the fan.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Krishna Janjanam
メンバー登録日: 11/08/16
206 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016人のメンバー
USFT-NANCE-F16S2G3
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 951
