メインコンテンツにスキップ
Asus Eee PC 1008ha Screen Replacement
必要な工具と部品
  1. Asus Eee PC 1008ha Screen Replacement, Battery: 手順 1、 1の画像 1
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Screen Replacement: 手順 2、 3の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 2、 3の画像 2 Asus Eee PC 1008ha Screen Replacement: 手順 2、 3の画像 3
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Screen Replacement: 手順 3、 2の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 3、 2の画像 2
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Screen Replacement, LCD Screen: 手順 4、 2の画像 1 Asus Eee PC 1008ha Screen Replacement, LCD Screen: 手順 4、 2の画像 2
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
    • Carefully pull the circuit board away from side of device base.
  5. Asus Eee PC 1008ha Screen Replacement: 手順 5、 3の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 5、 3の画像 2 Asus Eee PC 1008ha Screen Replacement: 手順 5、 3の画像 3
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
    • Gently lift the screen portion from the base.
  6. Asus Eee PC 1008ha Screen Replacement: 手順 6、 2の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 6、 2の画像 2
    • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
  7. Asus Eee PC 1008ha Screen Replacement: 手順 7、 2の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 7、 2の画像 2
    • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
  8. Asus Eee PC 1008ha Screen Replacement: 手順 8、 2の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 8、 2の画像 2
    • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
    • Use your fingers to hold the screen and carefully lift it from the base.
  9. Asus Eee PC 1008ha Screen Replacement: 手順 9、 2の画像 1 Asus Eee PC 1008ha Screen Replacement: 手順 9、 2の画像 2
    • Use your fingers to peel back the adhesive tape located on the back of the screen.
    • Disconnect the wire from the screen.
終わりに
ある他の人がこのガイドを完成しました。
作成者
9人の作成者と共同で作成されました。
Michael Dooley
メンバー登録日: 04/18/13
138 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G52
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 23
今までの合計 3,133
