はじめに
This task will normally be performed if the fan is faulty, broken, or if the user is trying to disassemble the entire device. You will start with removing the keyboard and continue to carefully remove parts within the laptop to finally disconnect fan for replacement.
  1. Using the plastic opening tool, carefully pry the top panel from the base.
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Lift the side of the keyboard. Disconnect the attached ribbon located underneath the keyboard. Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Use your fingers to lift the battery and gently disconnect the wires from the base. Use your fingers to lift the battery and gently disconnect the wires from the base.
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  5. Remove the 2mm screws on the copper heat sink on the left side of the device. Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink. Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink.
    • Remove the 2mm screws on the copper heat sink on the left side of the device.
    • Use a flathead screwdriver to remove the heat sink. Make sure to remove the adhesive tape from the top of the heat sink.
  6. Remove the small white connector attached to the fan (make sure to pull from the white connector and not with the wires as this can cause damage to the component) Replace with new fan!
    • Remove the small white connector attached to the fan (make sure to pull from the white connector and not with the wires as this can cause damage to the component)
    • Replace with new fan!
まとめ
2 の人々がこのガイドを完成させました。
Michael Dooley
メンバー登録日: 2013年04月18日
132 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G52
4 メンバー
6のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,449
