メインコンテンツにスキップ
Asus Eee PC 1005HA Keyboard Replacement
必要な工具と部品
  1. Asus Eee PC 1005HA Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Keyboard Replacement: 手順 2、 3の画像 1 Asus Eee PC 1005HA Keyboard Replacement: 手順 2、 3の画像 2 Asus Eee PC 1005HA Keyboard Replacement: 手順 2、 3の画像 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Keyboard Replacement, Keyboard: 手順 3、 2の画像 1 Asus Eee PC 1005HA Keyboard Replacement, Keyboard: 手順 3、 2の画像 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Keyboard Replacement: 手順 4、 3の画像 1 Asus Eee PC 1005HA Keyboard Replacement: 手順 4、 3の画像 2 Asus Eee PC 1005HA Keyboard Replacement: 手順 4、 3の画像 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
    It must be mentioned that you need to put the plastic opening tool above the F1, F6, between F10 and F11 and the Insert (Num Lock) Keys . It has 4 clips in total.
    Jakab Szilárd - 返信
  5. Asus Eee PC 1005HA Keyboard Replacement: 手順 5、 1の画像 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
    Step is missing. you also suppose to remove back screws, then rf shield screws, disconnect touchpad cable and then unclip and lift sides.
    Smoke Fumus - 返信
終わりに
12 の人々がこのガイドを完成させました。
作成者
14人の作成者と共同で作成されました。
Chris Beichler
メンバー登録日: 01/20/12
579 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 11-22, Maness Winter 2012 Cal Poly, Team 11-22, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S11G22
3 メンバー
12のガイドは作成済み
コメント 1 件
after i upgrade my bios keyboard stop working . but external keyboard working fine.. plz help
anytimerabin - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 4
過去 30 日: 17
今までの合計 23,416
