メインコンテンツにスキップ
Asus Eee PC 1005HA Hard Drive Replacement
必要な工具と部品
  1. Asus Eee PC 1005HA Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Hard Drive Replacement: 手順 2、 3の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 2、 3の画像 2 Asus Eee PC 1005HA Hard Drive Replacement: 手順 2、 3の画像 3
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Hard Drive Replacement, Keyboard: 手順 3、 2の画像 1 Asus Eee PC 1005HA Hard Drive Replacement, Keyboard: 手順 3、 2の画像 2
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Hard Drive Replacement: 手順 4、 3の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 4、 3の画像 2 Asus Eee PC 1005HA Hard Drive Replacement: 手順 4、 3の画像 3
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Hard Drive Replacement: 手順 5、 1の画像 1
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
  6. Asus Eee PC 1005HA Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 1 Asus Eee PC 1005HA Hard Drive Replacement, Hard Drive: 手順 6、 2の画像 2
    • Flip the laptop over.
    • Remove the four 5.65 mm screws from the bottom of the case.
    • Loosen the captive screw in the RAM compartment cover.
  7. Asus Eee PC 1005HA Hard Drive Replacement: 手順 7、 3の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 7、 3の画像 2 Asus Eee PC 1005HA Hard Drive Replacement: 手順 7、 3の画像 3
    • Remove the panel covering the RAM.
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • Gently pull the RAM chip out of its socket.
    • This photo shows the battery still attached, but it should be removed prior to removing or replacing the RAM.
  8. Asus Eee PC 1005HA Hard Drive Replacement: 手順 8、 1の画像 1
    • Remove the single 6.65 mm screw next to the RAM socket.
  9. Asus Eee PC 1005HA Hard Drive Replacement: 手順 9、 2の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 9、 2の画像 2
    • Flip the laptop back over and open the display.
    • Remove the six 5.5 mm screws from the metal plate beneath the keyboard.
  10. Asus Eee PC 1005HA Hard Drive Replacement: 手順 10、 2の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 10、 2の画像 2
    • Using a plastic opening tool, carefully detach the five plastic clips securing the upper case.
    • There are two small LEDs in the top edge of the lower casing, near the bottom right of the laptop. Be careful not to damage them as you pry open the plastic clips.
    • Carefully lift the upper case and flip it towards the front of the laptop.
  11. Asus Eee PC 1005HA Hard Drive Replacement: 手順 11、 1の画像 1
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Slide the trackpad ribbon cable from its socket.
  12. Asus Eee PC 1005HA Hard Drive Replacement: 手順 12、 3の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 12、 3の画像 2 Asus Eee PC 1005HA Hard Drive Replacement: 手順 12、 3の画像 3
    • Flip up the retaining flaps on each end of the I/O board ribbon cable ZIF connector.
    • Carefully pull the the I/O board ribbon cable from its sockets.
    • Remove the two 4.6 mm screws holding the hard drive in place.
  13. Asus Eee PC 1005HA Hard Drive Replacement: 手順 13、 2の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 13、 2の画像 2
    • Carefully slide the hard drive away from its socket.
    • Use the attached pull tab to lift the hard drive up and out of the case.
    • When reinstalling the hard drive, be sure that the WiFi antenna cable (visible as a black loop below the disk in the 2nd photo) is not trapped or pinched beneath the drive.
  14. Asus Eee PC 1005HA Hard Drive Replacement: 手順 14、 2の画像 1 Asus Eee PC 1005HA Hard Drive Replacement: 手順 14、 2の画像 2
    • Remove the four 3.6 mm screws from the hard drive tray.
    • Remove the hard drive from the tray.
終わりに
49 の人々がこのガイドを完成させました。
作成者
14人の作成者と共同で作成されました。
Mitchell Cesare
メンバー登録日: 01/31/12
802 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 11-22, Maness Winter 2012 Cal Poly, Team 11-22, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S11G22
3 メンバー
12のガイドは作成済み
10 件のコメント
What's the biggest hard drive that will work on this netbook?
Javier Molina - 返信
If I remember correctly, from the manufacturer, 500 GB should work. I had a WD 320 GB in it.
Elias Sunsetlover -
Great tutorial, thanks, I wouldn't have managed to change the drive without it, I couldn't figure out how to remove the keyboard, those latches are tricky...
julx64 - 返信
On the 1005HAB there is a piece of double sided tape under the backspace key on the keyboard. Other than that this guide works on the 1005HAB.
ejhoutman - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 23
過去 30 日: 212
今までの合計 100,947
