メインコンテンツにスキップ
Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement
  1. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement, Keyboard & Touchpad Assembly: 手順 1、 1の画像 1
    • Remove the ten 5 mm silver screws on the back panel.
    • Remove the back panel.
  2. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 2、 1の画像 1
    • Remove the black wire connected to the audio card.
    • Remove the white wire connected to the audio card.
  3. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 3、 1の画像 1
    • Remove the four 2.54 mm black screws connected to the battery and the speakers.
    • Take the battery out of the laptop
  4. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 4、 1の画像 1
    • Remove the black strips that connect to the display.
  5. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 5、 1の画像 1
    • Pry open the white gate, then disconnect the blue strip.
  6. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 6、 1の画像 1
    • Pry open the black gate and then disconnect the blue strip.
  7. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 7、 1の画像 1
    • Pry open the black gate, then disconnect the brown strip.
  8. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 8、 1の画像 1
    • Remove the two silver screws located in the middle of the motherboard that hold down the copper heatsink.
    • Remove the heatsink from the motherboard.
  9. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 9、 1の画像 1
    • Remove the eleven 2.5 mm screws from motherboard/daughterboard.
    • Remove the four 1.3 mm silver screws from the bottom of mother/daughterboard.
    • Remove the motherboard and daughterboard.
  10. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 10、 1の画像 1
    • Remove the six 2.5 mm black display screws.
  11. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: 手順 11、 1の画像 1
    • Remove the two 2.5 mm screws that secure the speakers.
    • Remove the speakers.
終わりに
作成者
6人の作成者と共同で作成されました。
NICKO SANTOS SALEM
メンバー登録日: 10/03/22
529 ポイント
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 172
