メインコンテンツにスキップ
Asus Chromebook Flip C100P Power and Volume Buttons Replacement
必要な工具と部品
  1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement, Power and Volume Buttons: 手順 1、 1の画像 1
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 2、 1の画像 1
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 3、 1の画像 1
    • Remove the eight 3mm bottom cover screws and one 6mm screw using a T5 screwdriver. Set apart the screw in the rear middle of the bottom cover from the the other eight screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 4、 3の画像 1 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 4、 3の画像 2 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 4、 3の画像 3
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require a bit of elbow grease. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 5、 3の画像 1 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 5、 3の画像 2 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 5、 3の画像 3
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 6、 2の画像 1 Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 6、 2の画像 2
    • Flip up the white part of the connector using the pointed end of a plastic spudge.
  7. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 7、 1の画像 1
    • Pull the cable out by the blue tab.
  8. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 8、 1の画像 1
    • Unscrew two 2.7 mm screws using the Phillips #0 screwdriver.
  9. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 9、 1の画像 1
    • Remove the button chip.
  10. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: 手順 10、 1の画像 1
    • Using tweezers, carefully pull out the external buttons.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Andrew Thomson
メンバー登録日: 03/19/18
181 ポイント
1ガイドが承認済み
チーム
Baylor, Team S5-G2, Williams Spring 2018 Baylor, Team S5-G2, Williams Spring 2018人のメンバー
BU-WILLIAMS-S18S5G2
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 704
