はじめに
If sound is dull or nonexistent from the Asus Chromebook C523N, use this guide to remove and replace your speakers.
Before using this guide, check the speaker for blockage that may be interfering with the sound. Usually, dust and debris can be cleared by a small dust blower. Make sure to check that the volume is not muted to confirm it needs replacing.
To begin this guide, check that the Chromebook’s power is off and it’s disconnected from any power source.
必要な工具と部品
Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
2 の人々がこのガイドを完成させました。
