メインコンテンツにスキップ
Asus Chromebook C300MA-EDU Speaker Replacement
必要な工具と部品
  1. Asus Chromebook C300MA-EDU Speaker Replacement, Keyboard: 手順 1、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement, Keyboard: 手順 1、 2の画像 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 2、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 2、 2の画像 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 3、 3の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 3、 3の画像 2 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 3、 3の画像 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU Speaker Replacement, Battery: 手順 4、 3の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement, Battery: 手順 4、 3の画像 2 Asus Chromebook C300MA-EDU Speaker Replacement, Battery: 手順 4、 3の画像 3
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 5、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 5、 2の画像 2
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 6、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 6、 2の画像 2
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU Speaker Replacement, Speaker: 手順 7、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement, Speaker: 手順 7、 2の画像 2
    • The speakers are connected to the CPU via a tabbed connection.
    • Using a smaller plastic spudger, gently pull backwards on the plastic clip until it comes loose.
  8. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 8、 3の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 8、 3の画像 2 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 8、 3の画像 3
    • Next, the speaker is incorporated into two plastic clips which are in the shell of the Chromebook.
    • Using a smaller plastic spudger, gently pull upward on the plastic clips from the outer edge of the speaker unit.
  9. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 9、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 9、 2の画像 2
    • After taking off the speaker unit from both sides, remove the tape holding down the central wiring in the middle of the Chromebook’s shell.
    • Using a plastic opening tool or spudger, slide the tool underneath a corner of tape and run the tool until the tape is removed.
  10. Asus Chromebook C300MA-EDU Speaker Replacement: 手順 10、 2の画像 1 Asus Chromebook C300MA-EDU Speaker Replacement: 手順 10、 2の画像 2
    • Gently slide the wire out from its casing.
    • The speaker is now disconnected safely.
終わりに
作成者
2人の作成者と共同で作成されました。
Christopher Hart
メンバー登録日: 09/28/17
501 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S2-G3, Nance Fall 2017 USF Tampa, Team S2-G3, Nance Fall 2017人のメンバー
USFT-NANCE-F17S2G3
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 172
