必要な工具と部品
Flip the Chromebook onto its back, where there are eleven screws.
There are two variations of screws on the back panel:
Six 8.7mm screws.
Five 6.4mm screws.
Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
Once the keyboard is removed, the battery is located on the bottom portion of the shell.
The battery is held in with six 6.5mm screws on opposing sides.
Placing the Chromebook in the upright position, the LAN card is located on the upper right side of the shell.
The LAN card is pinned down with 2 coaxial connectors: main power and auxiliary input.
To disconnect, gently pull off the two connections using an upwards motion.
