メインコンテンツにスキップ
Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement
必要な工具と部品
  1. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement, Back Cover: 手順 1、 1の画像 1
    • Place device bottom-side up.
  2. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 2、 1の画像 1
    • Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
    • Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
  3. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 3、 1の画像 1
    • Using a plastic opening tool, separate the bottom case at the seam.
    • Prying open a laptop requires a lot of force but use caution so as to avoid breaking the fragile connectors.
  4. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 4、 2の画像 1 Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 4、 2の画像 2
    • Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
  5. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement, Battery: 手順 5、 1の画像 1
    • Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
  6. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 6、 1の画像 1
    • Unplug the wire using the plastic opening tool that connects the battery with the board.
  7. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 7、 1の画像 1
    • Lift the battery out of the laptop
  8. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement, Speakers: 手順 8、 1の画像 1
    • Use plastic opening tool to pry off the wire connecting the left side speaker to the circuit board.
  9. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 9、 2の画像 1 Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 9、 2の画像 2
    • Use plastic opening tool to pry off the left side speaker.
  10. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 10、 1の画像 1
    • Gently remove the wire connecting the left and right speakers from it's channel. Be careful as to not tear or damage the wire.
  11. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 11、 1の画像 1
    • Use plastic opening tool to pry off right side speaker.
  12. Asus Chromebook C300MA-DB01 Speaker Replacement Speakers Replacement: 手順 12、 1の画像 1
    • Lift and remove both speakers and connecting wire.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
wyatt boyatt
メンバー登録日: 09/25/17
541 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S4-G3, Eyestone Fall 2017 USF Tampa, Team S4-G3, Eyestone Fall 2017人のメンバー
USFT-EYESTONE-F17S4G3
3 メンバー
12のガイドは作成済み
2 件のコメント
Bonjour m. Merci pour la présentation. Pourriez-vous m'indiquer l'endroit où je peux me procurer des haut-parleurs pour un hp Omen 15 ? Merci d'avance. Email : dhujardaim@hotmail.com / dhujardaim@gmail.com
dhujardaim@hotmail.com - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 146
