はじめに
This guide details how to replace the screen if it is cracked or not working properly. During this process be sure to avoid resting your arm or hand in the adhesive on the motherboard.
必要な工具と部品
Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
Wiggle the plate back and forth to loosen the adhesive under the plate.
Rotate the screwdriver in a counterclockwise direction to remove the screws.
Unscrew the 4mm screws with a Phillips #0 screwdriver by rotating the screwdriver counterclockwise.
もう少しです!
終わりに
