はじめに
The fan is an important part of the cooling system. It protects hardware from overheating and also helps keep things clean on the motherboard. Having a functional fan protects the different systems involved in cooling.
This replacement guide will require the opening and working on the inside of your Asus CM1745. This replacement guide will show you how to replace a case fan in your Asus CM1745 that may not be working anymore.
To ensure safety, unplug the power supply and turn it off.
必要な工具と部品
Remove the side panel by unscrewing the two screws fastening the panel on the rear.
Once unscrewed, slide the panel towards the rear until it releases then lift away.
Once finished, plug in the computer and turn it on to test if the new fan works and is installed correctly. If everything works as it should, replace the side panel and resecure the screws in the rear.
ある他の人がこのガイドを完成しました。
