はじめに
Remove the lower case of the ASUS A52F XE2 to gain access to internal parts.
必要な工具と部品
Place the laptop face down with the battery facing away from you.
Locate the two buttons next to the battery.
Slide the right slider to the unlocked (red) position.
Remove the five Phillips # 0 screws from the back panel.
Using your finger or a plastic spudger start to carefully pry up the back planel.
ある他の人がこのガイドを完成しました。
