必要な工具と部品
Remove screws at the circles
Remove gum strap and screw 5 screws out
Use a big screwdriver or some plastic to softly open the entire case around, starting at one down corner where your removed the screws before. The plastic clips will click a little. Don't be to hard.
Then you can lay the back next to the front, see second picture.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
