はじめに
This will guide you through the process of replacing your Astro Pyle PTBL7C's speakers.
必要な工具と部品
Slide the flat end of the spudger under the front edge of the screen and carefully pry it open.
Locate the Speakers; they should be attached to the case as shown.
Follow the wires back to the motherboard, removing all tape covering the wires along the way.
Desolder the black wire from the motherboard. This will separate the speakers from the board, allowing you to replace them.
もう少しです!
終わりに
