メインコンテンツにスキップ
Astro Mixamp USB Port Replacement
必要な工具と部品
  1. Astro Mixamp USB Port Replacement, Panel Dial: 手順 1、 2の画像 1 Astro Mixamp USB Port Replacement, Panel Dial: 手順 1、 2の画像 2
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp USB Port Replacement: 手順 2、 2の画像 1 Astro Mixamp USB Port Replacement: 手順 2、 2の画像 2
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp USB Port Replacement, Outer Casing: 手順 3、 2の画像 1 Astro Mixamp USB Port Replacement, Outer Casing: 手順 3、 2の画像 2
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp USB Port Replacement: 手順 4、 1の画像 1
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp USB Port Replacement: 手順 5、 1の画像 1
    • Gently lift the rear casing from the device.
    The Astro Mixamp Pro is largely the same process as this, except there are some plastic tabs on the rear casing holding it onto the front plate. Carefully work along the seams on the long sides and the corners with something flat and stiff, gently levering the rear housing out and away from the front plate to disengage the plastic tabs. With enough patience and care, they'll pop out of their spots and the casing will be free.
    foshwosh - 返信
  6. Astro Mixamp USB Port Replacement, Motherboard: 手順 6、 3の画像 1 Astro Mixamp USB Port Replacement, Motherboard: 手順 6、 3の画像 2 Astro Mixamp USB Port Replacement, Motherboard: 手順 6、 3の画像 3
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp USB Port Replacement: 手順 7、 1の画像 1
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp USB Port Replacement, USB Port: 手順 8、 3の画像 1 Astro Mixamp USB Port Replacement, USB Port: 手順 8、 3の画像 2 Astro Mixamp USB Port Replacement, USB Port: 手順 8、 3の画像 3
    • Press the tip of a hot soldering iron to the USB connection to melt the solder.
    • Use a nylon spudger to lift the USB from the solder.
    • Repeat for each of the four USB connections.
    • For more help on soldering, refer to this guide: はんだ付けとはんだ除去の作業ガイド
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Hope Burns
メンバー登録日: 10/29/16
741 ポイント
5のガイドは作成済み
チーム
IUPUI, Team 3-3, Wilson Fall 2016 IUPUI, Team 3-3, Wilson Fall 2016人のメンバー
IUPUI-WILSON-F16S3G3
3 メンバー
5のガイドは作成済み
4 件のコメント
What port is used as a replacement?
jonescoleman1738 - 返信
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
MoreZemtor - 返信
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 7,808
