はじめに
Use this guide to remove control buttons for cleaning or replacement.
パーツ
パーツは指定されていません。
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Gently insert a metal spudger under a control button housing.
Rotate the control button around the marked pin.
ある他の人がこのガイドを完成しました。
