メインコンテンツにスキップ
Astro C40 TR Joystick Replacement
必要な工具と部品
  1. Astro C40 TR Joystick Replacement, Joystick: 手順 1、 1の画像 1
    • Unplug your controller from the video game console.
    • Turn the wireless mode off if it is activated on your controller.
  2. Astro C40 TR Joystick Replacement: 手順 2、 3の画像 1 Astro C40 TR Joystick Replacement: 手順 2、 3の画像 2 Astro C40 TR Joystick Replacement: 手順 2、 3の画像 3
    • Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
    • Remove the face cover of the joystick by flipping the controller on its side.
    • Don't panic if the joystick falls off! It can be placed back on.
  3. Astro C40 TR Joystick Replacement: 手順 3、 3の画像 1 Astro C40 TR Joystick Replacement: 手順 3、 3の画像 2 Astro C40 TR Joystick Replacement: 手順 3、 3の画像 3
    • Use the 30mm TORX Screwdriver to remove the screws from the module.
    • Push on the top frame until it pops off of the module.
    • If you have a whole new joystick module, you can skip to step 6.
  4. Astro C40 TR Joystick Replacement: 手順 4、 3の画像 1 Astro C40 TR Joystick Replacement: 手順 4、 3の画像 2 Astro C40 TR Joystick Replacement: 手順 4、 3の画像 3
    • Connect the base frame replacement to the joystick module.
    • Insert the top frame on the module until it clicks back together.
  5. Astro C40 TR Joystick Replacement: 手順 5、 3の画像 1 Astro C40 TR Joystick Replacement: 手順 5、 3の画像 2 Astro C40 TR Joystick Replacement: 手順 5、 3の画像 3
    • Reassemble the joystick module and plug it back into the controller.
    • Make sure the replacement and base frame are tightly screwed together.
    • Align the module and controller as you put joystick back together.
  6. Astro C40 TR Joystick Replacement: 手順 6、 2の画像 1 Astro C40 TR Joystick Replacement: 手順 6、 2の画像 2
    • Reassemble the controller by placing the face cover back on.
    • Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
    • If it's difficult to tighten the screws, don't force it. The joystick and controller are probably not aligned correctly!
  7. Astro C40 TR Joystick Replacement: 手順 7、 1の画像 1
    • Recalibrate the controller so the new joystick can be detected by the console.
    • Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
    • Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
終わりに
作成者
5人の作成者と共同で作成されました。
Pan
メンバー登録日: 09/13/21
145 ポイント
1ガイドが承認済み
チーム
York University, Team E-21, Melo-Thaiss Fall 2021 York University, Team E-21, Melo-Thaiss Fall 2021人のメンバー
YORK-MELO-THAISS-F21SEG21
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 53
今までの合計 3,891
