はじめに
The guide allows for you to take apart and replace the channel selection switch on an Astro A50 gaming headset with only a Phillips head screwdriver.
必要な工具と部品
3 件のコメント
This is great, thank you. My switch has been broken for two years, now I can get to fixing it.
Question: Once we have taken it apart, do we simply replace the switch or is there a contact on the switch itself, PCB or wire that needs to be re-attached or adjusted?
Thanks!
-Brandon
where did you get the part to replace it? Can’t find just the little switch anywhere.
This is perfect. But where do you get a new switch? Can’t find just the tiny part anywhere.
