メインコンテンツにスキップ
Astro A50 Channel Selection Switch Replacement
必要な工具と部品
  1. Astro A50 Channel Selection Switch Replacement, Channel Selection Switch: 手順 1、 2の画像 1 Astro A50 Channel Selection Switch Replacement, Channel Selection Switch: 手順 1、 2の画像 2
    • Remove the foam ear padding by pulling it straight to you
  2. Astro A50 Channel Selection Switch Replacement: 手順 2、 1の画像 1
    • Remove the four 3.5mm Phillips head screws circled in red, and remove the grey cover.
  3. Astro A50 Channel Selection Switch Replacement: 手順 3、 1の画像 1
    • Remove the four 3.5mm Phillips head screws circled in red and remove the silver cover.
  4. Astro A50 Channel Selection Switch Replacement: 手順 4、 2の画像 1 Astro A50 Channel Selection Switch Replacement: 手順 4、 2の画像 2
    • Remove the four 3.5mm Phillips head screws.
    • Remove the 3.5mm Phillips head screw circled in blue to remove secondary motherboard.
  5. Astro A50 Channel Selection Switch Replacement: 手順 5、 1の画像 1
    • Separate the secondary mother board from the motherboard by pulling firmly to the right on the white connector.
  6. Astro A50 Channel Selection Switch Replacement: 手順 6、 1の画像 1
    • Finally push the channel selector in towards the motherboard to remove it from the headset casing. The switch is pointed to by the screwdriver inside the red square.
終わりに
作成者
1人の作成者と共同作成されました。
William Czerwonka
メンバー登録日: 09/21/17
228 ポイント
2のガイドは作成済み
チーム
IUPUI, Team S1-G1, Baechle Fall 2017 IUPUI, Team S1-G1, Baechle Fall 2017人のメンバー
IUPUI-BAECHLE-F17S1G1
2 メンバー
6のガイドは作成済み
3 件のコメント
This is great, thank you. My switch has been broken for two years, now I can get to fixing it.
Question: Once we have taken it apart, do we simply replace the switch or is there a contact on the switch itself, PCB or wire that needs to be re-attached or adjusted?
Thanks!
-Brandon
Brandon Thomas - 返信
where did you get the part to replace it? Can’t find just the little switch anywhere.
Justin Sykes -
This is perfect. But where do you get a new switch? Can’t find just the tiny part anywhere.
Justin Sykes - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 2,243
