はじめに
This page will guide you how to replace the speaker on your Astro A40 TR Speakers headset. Please make sure device is powered off and be wary of any exposed wires. (Time estimate to replace speaker and reassemble: around 12 minutes - experience levels vary)
必要な工具と部品
To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
2 の人々がこのガイドを完成させました。
2 件のコメント
I’ve found potential replacement speakers here. They look fairly similar to the ones in the A40s, but the resistance value marked on the speakers in the guide vs on the listing is different.
Buyer caution must be taken before actually making the plunge, as sound quality might be different. The listing is from Ali Express after all.
