メインコンテンツにスキップ
Astak Mole Motherboard Replacement
必要な工具と部品
  1. Astak Mole Motherboard Replacement, Lower Case: 手順 1、 1の画像 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Motherboard Replacement: 手順 2、 1の画像 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Motherboard Replacement: 手順 3、 1の画像 1
    • Remove the SD card.
  4. Astak Mole Motherboard Replacement: 手順 4、 1の画像 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Motherboard Replacement: 手順 5、 1の画像 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Motherboard Replacement, Motherboard: 手順 6、 2の画像 1 Astak Mole Motherboard Replacement, Motherboard: 手順 6、 2の画像 2
    • Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
    • All wired connections to the motherboard are removed by the thin plastic male connector inserted into the larger female plastic connection.
  7. Astak Mole Motherboard Replacement: 手順 7、 2の画像 1 Astak Mole Motherboard Replacement: 手順 7、 2の画像 2
    • The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
    • Be careful not to scratch the CPU in this step. This is not a wired connection.
    • Sever the additional adhesive connections so that the wired connections may be removed.
  8. Astak Mole Motherboard Replacement: 手順 8、 1の画像 1
    • Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
    • Screw Measurements: (Length= 5.3mm)
  9. Astak Mole Motherboard Replacement: 手順 9、 2の画像 1 Astak Mole Motherboard Replacement: 手順 9、 2の画像 2
    • Remove the last two wired connections to the motherboard by severing the indicated connections.
    • Lift up the secondary motherboard as indicated using the metal spudger.
    • All connections should be severed from the motherboard and a new motherboard may be inserted.
    • It is advised to reapply adhesive to wired connections during reassembly.
終わりに
作成者
5人の作成者と共同で作成されました。
Andrew Birch
メンバー登録日: 09/15/16
204 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016人のメンバー
USFT-BLACKWELL-F16S2G2
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 686
