メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
The expansion pipe allows the angle of the parabolic dish to be adjusted in order to achieve maximum light focus on the cooker flat. The T-bar also supports the weight of the entire parabolic solar panels.
ツール
パーツ
パーツは指定されていません。
  1. Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side. Be sure the flat side of each tripod leg is facing toward the ground.
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  3. Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly. It does not matter which direction the 14mm bolt is inserted from.
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
終わりに
To disassemble your device, follow these instructions in reverse order.
ある他の人がこのガイドを完成しました。
Ashlie Reott
メンバー登録日: 2013年10月20日
328 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013人のメンバー
CPSU-AMIDO-F13S4G30
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 358
