はじめに
The expansion pipe allows the angle of the parabolic dish to be adjusted in order to achieve maximum light focus on the cooker flat. The T-bar also supports the weight of the entire parabolic solar panels.
必要な工具と部品
Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
To disassemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
