メインコンテンツにスキップ
Aroma ARC-914SBD Push Button Interface Replacement
必要な工具と部品
  1. Aroma ARC-914SBD Push Button Interface Replacement, Lid: 手順 1、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement, Lid: 手順 1、 2の画像 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Push Button Interface Replacement: 手順 2、 1の画像 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Push Button Interface Replacement: 手順 3、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement: 手順 3、 2の画像 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Push Button Interface Replacement: 手順 4、 3の画像 1 Aroma ARC-914SBD Push Button Interface Replacement: 手順 4、 3の画像 2 Aroma ARC-914SBD Push Button Interface Replacement: 手順 4、 3の画像 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
  5. Aroma ARC-914SBD Push Button Interface Replacement, Push Button Interface: 手順 5、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement, Push Button Interface: 手順 5、 2の画像 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry the bottom edge of this piece outward (away from the stainless steel side) about 1/4 inch to pull the tab out of it's hole. Once the bottom is pried out a bit, the tab can be seen from the bottom. Press up on the tab with a screwdriver.
  6. Aroma ARC-914SBD Push Button Interface Replacement: 手順 6、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement: 手順 6、 2の画像 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. Aroma ARC-914SBD Push Button Interface Replacement: 手順 7、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement: 手順 7、 2の画像 2
    • Using a Phillips head screwdriver, size PH2, remove screws from the control module to expose wired connections.
  8. Aroma ARC-914SBD Push Button Interface Replacement: 手順 8、 1の画像 1
    • Unplug the interface from control module.
  9. Aroma ARC-914SBD Push Button Interface Replacement: 手順 9、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement: 手順 9、 2の画像 2
    • Remove the two screws holding the cardboard cover over the Interface using a Phillips head screwdriver, size PH2.
  10. Aroma ARC-914SBD Push Button Interface Replacement: 手順 10、 2の画像 1 Aroma ARC-914SBD Push Button Interface Replacement: 手順 10、 2の画像 2
    • Using a Phillips head screwdriver, size PH2, remove the four screws holding the interface in place.
終わりに
ある他の人がこのガイドを完成しました。
作成者
7人の作成者と共同で作成されました。
Brandon Nieves
メンバー登録日: 09/04/15
956 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 2-3, Sullivan Fall 2015 USF Tampa, Team 2-3, Sullivan Fall 2015人のメンバー
USFT-SULLIVAN-F15S2G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 11
今までの合計 484
