メインコンテンツにスキップ
ArmorAll AA255 Power Cord Replacement
必要な工具と部品
  1. ArmorAll AA255 Power Cord Replacement, Lower Motor Housing: 手順 1、 1の画像 1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Power Cord Replacement: 手順 2、 1の画像 1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Power Cord Replacement: 手順 3、 1の画像 1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Power Cord Replacement: 手順 4、 2の画像 1 ArmorAll AA255 Power Cord Replacement: 手順 4、 2の画像 2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Power Cord Replacement, Power Cord: 手順 5、 1の画像 1
    • Pull the black wire from the power cord out of the switch.
    • There are no clips or tabs that hold this wire in place. Just pull strongly to remove it.
    • Don't remove both black wires. Only the black wire that comes from the power cord itself needs to be removed. The one going to the motor can be left alone.
  6. ArmorAll AA255 Power Cord Replacement: 手順 6、 1の画像 1
    • Remove the five 15mm screws from the plastic motor cover and power cord clamp using a PH2 screwdriver.
  7. ArmorAll AA255 Power Cord Replacement: 手順 7、 2の画像 1 ArmorAll AA255 Power Cord Replacement: 手順 7、 2の画像 2
    • Remove the plastic motor cover.
    • Be sure to loosen the white wire from the notch in the plastic motor cover by pulling it upwards.
  8. ArmorAll AA255 Power Cord Replacement: 手順 8、 2の画像 1 ArmorAll AA255 Power Cord Replacement: 手順 8、 2の画像 2
    • Detach the white wire from the motor by pulling upwards on the wire as you depress the small metal tab on the connector with a nylon spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Abel Manring
メンバー登録日: 02/10/16
263 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-1, Baechle Spring 2016 IUPUI, Team 2-1, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 15
今までの合計 976
