メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
はじめに
The device will be disassembled down to the motor, the power cords will be disconnected, and the motor removed.
  1. Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. Remove the five 15mm PH2 screws.
    • Remove the five 15mm PH2 screws.
  3. Remove the 15 mm T20 screw. This screw is located nearest the power cord.
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. Gently separate the upper and lower sections of the main housing. Gently separate the upper and lower sections of the main housing.
    • Gently separate the upper and lower sections of the main housing.
  5. Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing. Pull the ball cage to remove it from the main housing. Pull the ball cage to remove it from the main housing.
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. Remove one 13mm nut from the main housing. The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury. Remove metal ring from the main housing.
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. Turn the whole body over to separate motor cover. Use a PH2 screwdriver to remove the five 15mm screw. Remove the white power wire from the motor cover.
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. The motor is ready for replacement. Pull the motor to separate. The motor is ready for replacement. Pull the motor to separate.
    • The motor is ready for replacement. Pull the motor to separate.
終わりに
4 の人々がこのガイドを完成させました。
YeaJun Yoo
メンバー登録日: 2016年02月11日
248 ポイント
1ガイドが承認済み
チーム
IUPUI, Team 2-1, Baechle Spring 2016 IUPUI, Team 2-1, Baechle Spring 2016人のメンバー
IUPUI-BAECHLE-S16S2G1
4 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 19
過去 30 日: 38
今までの合計 1,131
