メインコンテンツにスキップ
Archos 97 Carbon Display Screen Replacement
必要な工具と部品
  1. Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: 手順 1、 2の画像 1 Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: 手順 1、 2の画像 2
    • Lay your tablet upwards facing you.
    • Using the opening tool, begin by prying the tablet starting in the top left corner. This can be found near the volume and power buttons.
    • Begin to work your way around the tablet in a clockwise motion to separate the screen from the cover.
  2. Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 手順 2、 3の画像 1 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 手順 2、 3の画像 2 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 手順 2、 3の画像 3
    • Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
    • Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
  3. Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: 手順 3、 2の画像 1 Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: 手順 3、 2の画像 2
    • On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • The screen should be separated from the tablet.
  4. Archos 97 Carbon Display Screen Replacement, Removing the screws: 手順 4、 2の画像 1 Archos 97 Carbon Display Screen Replacement, Removing the screws: 手順 4、 2の画像 2
    • Remove the screws on the backside of the screen using a screwdriver.
    • There are four screws; one is covered by tape.
  5. Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 手順 5、 3の画像 1 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 手順 5、 3の画像 2 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 手順 5、 3の画像 3
    • Gently pry the screen from the black frame that surrounds it using the opening tool.
    • Work in a clockwise motion until the screen is detached from the frame.
終わりに
2 の人々がこのガイドを完成させました。
作成者
9人の作成者と共同で作成されました。
Allyson Seber
メンバー登録日: 03/03/15
311 ポイント
2のガイドは作成済み
チーム
Sam Houston State, Team 13-5, Blackburne Winter 2015 Sam Houston State, Team 13-5, Blackburne Winter 2015人のメンバー
SHSU-BLACKBURNE-W15S13G5
3 メンバー
8のガイドは作成済み
コメント 1 件
Hi,
Is this similar to replacing the touch screen on the Archos 101B model?.
colin - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,578
