メインコンテンツにスキップ
Archos 5 Battery Replacement
必要な工具と部品
  1. Archos 5 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Please be sure that your device is powered off before attempting any repairs.
    • Please be aware that any further steps could possibly void the warranty of your Archos 5.
  2. Archos 5 Battery Replacement: 手順 2、 2の画像 1 Archos 5 Battery Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
    • Use the screwdriver(PH000) to remove the screws located under the pads.
    • Lift the stand in order to get to the fourth screw.
  3. Archos 5 Battery Replacement: 手順 3、 2の画像 1 Archos 5 Battery Replacement: 手順 3、 2の画像 2
    • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
    • Once all sides of the device are pried open, gently open the device .
    • Be careful not to tear the foil which connects the LCD screen to the motherboard!
  4. Archos 5 Battery Replacement: 手順 4、 2の画像 1 Archos 5 Battery Replacement: 手順 4、 2の画像 2
    • Once you have opened your device, fold the screen away from the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
  5. Archos 5 Battery Replacement: 手順 5、 1の画像 1
    • Separate the grey tape by using a plastic spudger. The tape is holding the battery in place.
  6. Archos 5 Battery Replacement: 手順 6、 3の画像 1 Archos 5 Battery Replacement: 手順 6、 3の画像 2 Archos 5 Battery Replacement: 手順 6、 3の画像 3
    • Now begin to remove the battery by prying it away with the plastic spudger. Please note that the battery is glued to the device.
    • Be careful when prying the battery away from the device. Wiggle the plastic spudger under the battery if necessary to loosen the glue.
  7. Archos 5 Battery Replacement: 手順 7、 1の画像 1
    • Locate 3 wires(red, blue and black) that connect the motherboard and the battery.
  8. Archos 5 Battery Replacement: 手順 8、 3の画像 1 Archos 5 Battery Replacement: 手順 8、 3の画像 2 Archos 5 Battery Replacement: 手順 8、 3の画像 3
    • After locating the wires (red, blue, and black) firmly pull the wires using tweezers and release them from the motherboard.
    • Continue to does this to the remaining two wires.
  9. Archos 5 Battery Replacement: 手順 9、 1の画像 1
    • Once the wires have all been released remove the battery from the device and replace with a new battery. To reattach the new battery wires please refer to this guide on How To Solder
    Excellent instructions - but the eBay link for the battery specifies a Archos55 battery, which does not fit!!
    OE1NMB - 返信
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ally Hummel
メンバー登録日: 09/22/15
378 ポイント
3のガイドは作成済み
チーム
University of Alabama, Team 1-5, Sydow campbell Fall 2015 University of Alabama, Team 1-5, Sydow campbell Fall 2015人のメンバー
UA-SYDOW CAMPBELL-F15S1G5
4 メンバー
6のガイドは作成済み
2 件のコメント
Where I can find this battery?
mitkekg - 返信
CA564889 - Battery
mitkekg - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 111
今までの合計 10,698
