メインコンテンツにスキップ
Archos 101 G9 Speaker Replacement
必要な工具と部品
  1. Archos 101 G9 Speaker Replacement, Display Assembly: 手順 1、 1の画像 1
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Speaker Replacement: 手順 2、 2の画像 1 Archos 101 G9 Speaker Replacement: 手順 2、 2の画像 2
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Speaker Replacement: 手順 3、 2の画像 1 Archos 101 G9 Speaker Replacement: 手順 3、 2の画像 2
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Speaker Replacement: 手順 4、 1の画像 1
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Speaker Replacement: 手順 5、 1の画像 1
    • Remove the display assembly from the back panel.
  6. Archos 101 G9 Speaker Replacement, Speaker: 手順 6、 2の画像 1 Archos 101 G9 Speaker Replacement, Speaker: 手順 6、 2の画像 2
    • Pry the speaker free from the case using a nylon spudger.
  7. Archos 101 G9 Speaker Replacement: 手順 7、 1の画像 1
    • Remove the tape covering the connections on the motherboard.
  8. Archos 101 G9 Speaker Replacement: 手順 8、 1の画像 1
    • Desolder the HP+ connection on the motherboard.
    • Desolder the HP- connection on the motherboard.
    • Be cautious when using the soldering iron.
    • Remove the speaker from the tablet.
終わりに
作成者
2人の作成者と共同で作成されました。
Clay Meunier
メンバー登録日: 10/28/21
557 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021人のメンバー
UMASSD-GULBRANDSEN-F21S4G1
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 81
