はじめに
When you “keep” pet fish, you are not just keeping the individual fish themselves. Rather you are really keeping the water that those fish live in. Fish produce waste which will make the water they live in toxic, so it is their owner’s responsibility to keep their water clean. An aquarium filter is often used to maintain the livability of the aquarium water. The filter media provides nitrifying bacteria a place to establish a colony. This bacteria takes deadly compounds produced from fish waste, like ammonia, and converts it into less toxic compounds that can be removed with regular water changes. Every aquarium in the world that supports life contains these bacteria. The filter media is where the majority of then nitrifying bacteria in your tank will live.
Often, commercially produced aquarium filters come with cheap sponges which are meant to act as this medium. Unfortunately, these sponges can deteriorate quickly and replacement sponges must be purchased. However instead of purchasing a new sponge medium, one can simply produce their own long lasting and effective media with a little bit of effort. This guide will go over creating, preparing, and using your own aquarium filter media made from PVC pipe.
Never replace more than 25% of your filter media at once.
必要な工具と部品
Get a PVC pipe with a small diameter; less than 5 cm is ideal.
Rub the outer surface of the PVC pipe with 120 grit sandpaper to create a rough surface.
Put all of the small cut pieces into a container that can hold water.
Unplug your aquarium filter.
Lift the lid of your aquarium filter's canister.
Carefully remove 10-25% of your biological filter media.
Slowly replace the existing biological with your new pipe media: 10-25% a week, during water changes, is ideal to avoid ammonia spikes.
Enjoy your long-lasting biological media!
