メインコンテンツにスキップ
Apple iPod Hi-Fi Power Supply Replacement
必要な工具と部品
  1. Apple iPod Hi-Fi Power Supply Replacement, Grille: 手順 1、 1の画像 1
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Power Supply Replacement: 手順 2、 1の画像 1
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Power Supply Replacement: 手順 3、 1の画像 1
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
  4. Apple iPod Hi-Fi Power Supply Replacement, Front Panel and Speaker Connections: 手順 4、 2の画像 1 Apple iPod Hi-Fi Power Supply Replacement, Front Panel and Speaker Connections: 手順 4、 2の画像 2
    • Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
    • Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
  5. Apple iPod Hi-Fi Power Supply Replacement: 手順 5、 2の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 5、 2の画像 2
    • Pry out the large speaker with a metal spudger around the edge.
    • Remove the speaker slowly from its socket with your hands.
    • Turning the speaker on its side will make this step much easier.
    • The speaker is still attached by several connections at this point so the speaker will not be able to be removed completely at this step.
  6. Apple iPod Hi-Fi Power Supply Replacement: 手順 6、 2の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 6、 2の画像 2
    • Press down on the tab and pull out with your hands to remove the cable connecting the large speaker from the rest of the unit.
    • Pull the large speaker completely out and set aside.
  7. Apple iPod Hi-Fi Power Supply Replacement: 手順 7、 1の画像 1
    • Remove the sensor connection by pulling it straight out with your hand.
  8. Apple iPod Hi-Fi Power Supply Replacement: 手順 8、 3の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 8、 3の画像 2 Apple iPod Hi-Fi Power Supply Replacement: 手順 8、 3の画像 3
    • Pull the entire front assembly off by prying it up with the spudger and lifting the assembly off with your hands towards the top of the Hi-Fi.
    • There are still connections attached at this stage so the front assembly will not completely disconnect from the rest of the device .
  9. Apple iPod Hi-Fi Power Supply Replacement: 手順 9、 2の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 9、 2の画像 2
    • Remove the clips for the remaining two speakers by repeating step 6.
    • Remove the last connection that connects the speakers to the power box.
    • Remove the front panel completely.
    • When reassembling, the ports are labeled "right" and "left" to help you plug in the right speaker to the right port.
  10. Apple iPod Hi-Fi Power Supply Replacement, iPod Dock Inserts: 手順 10、 1の画像 1
    • Place the speaker on its back with the dock facing away from you.
  11. Apple iPod Hi-Fi Power Supply Replacement: 手順 11、 1の画像 1
    • Remove the cable connected to the dock insert by pulling the cable straight out.
  12. Apple iPod Hi-Fi Power Supply Replacement: 手順 12、 2の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 12、 2の画像 2
    • Remove the gold tape attaching the insert to the unit.
    • Remove the three 2mm Phillips #1 screws holding the dock inserts in by placing the screwdriver in the head of the screw and rotating counterclockwise.
  13. Apple iPod Hi-Fi Power Supply Replacement: 手順 13、 1の画像 1
    • Remove the dock insert with your hands.
  14. Apple iPod Hi-Fi Power Supply Replacement, Power Supply: 手順 14、 1の画像 1
    • Unplug the 2 cables on the top of the power supply box.
    • Unclip the cables clipped together to the left of the power supply box.
  15. Apple iPod Hi-Fi Power Supply Replacement: 手順 15、 1の画像 1
    • Remove the middle foam panel from the wall of the device closest to you by pulling the foam out with your hand.
  16. Apple iPod Hi-Fi Power Supply Replacement: 手順 16、 3の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 16、 3の画像 2 Apple iPod Hi-Fi Power Supply Replacement: 手順 16、 3の画像 3
    • Remove two 2mm Phillips #1 screws from the back power port by placing the screwdriver in the head of the screw and rotating counterclockwise.
    • Pull the power port straight out of its socket with your hands. The power port should come right out.
  17. Apple iPod Hi-Fi Power Supply Replacement: 手順 17、 2の画像 1 Apple iPod Hi-Fi Power Supply Replacement: 手順 17、 2の画像 2
    • Remove four 2mm Phillips #1 screws from the base of the power supply box by placing the screwdriver in the head of the screw and rotating counterclockwise.
  18. Apple iPod Hi-Fi Power Supply Replacement: 手順 18、 1の画像 1
    • Remove the power supply box with your hands.
終わりに
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tanner McCormack
メンバー登録日: 04/16/18
493 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G1
5 メンバー
16のガイドは作成済み
6 件のコメント
It not just the power supply. The amplifier board is attached to the top.
Tom Karches - 返信
Where can we find a compatible power suply? Thank you.
Victor Rizescu - 返信
Bonjour le tutoriel est très bien mais ou peut-on acheter le bloc d’alimentation ?
Merci
castan.vincent - 返信
where can i find a power supply please .
chris snook - 返信
What is the Part Number of the Apple iPod Hi-Fi internal Power Supply and Amplifier Assembly?
Roosevelt Adrianza - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 115
今までの合計 8,083
