メインコンテンツにスキップ
Apple iPod Hi-Fi Batteries Replacement
必要な工具と部品
  1. Apple iPod Hi-Fi Batteries Replacement, Batteries: 手順 1、 1の画像 1
    • Put your coin in the battery lock on the back of the the Hi-Fi. Turn the coin to the left to release the battery panel.
    • Remove the battery panel with your hands.
    • You can also use a metal spudger or flathead screwdriver to open the battery lock instead of a coin.
  2. Apple iPod Hi-Fi Batteries Replacement: 手順 2、 1の画像 1
    • Remove the six D batteries from the device.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Timothy Scheuermann
メンバー登録日: 04/18/18
710 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S16-G1, Livingston Spring 2018 Cal Poly, Team S16-G1, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S16G1
5 メンバー
16のガイドは作成済み
3 件のコメント
good day.  Does the column charge the batteries when it is plugged in?
pay4e4ek777 - 返信
Nope, the hifi will not charge any batteries that are installed.
Josh Calvetti -
Hello, I realize these comments/texts are a bit old (2019) however, I have an Apple Speaker unit from 2006 that is practically new with very little usage but stopped working due to purchasing a Bluetooth adaptor and inserting it in the rear (Audio in) jack. It had been working “great” with the Bluetooth and my iPhone for a while until the speaker unit ceased to function-turn back on (no power). Can you kindly assist in assessing-determining what might have gone wrong and what would be required to fix this problem. Many thanks ahead. Look forward to your reply.
Roosevelt Adrianza - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 24
過去 30 日: 100
今までの合計 4,698
