メインコンテンツにスキップ
Apple XServe Raid Battery Replacement
必要な工具と部品
  1. Apple XServe Raid Battery Replacement, Raid Battery: 手順 1、 2の画像 1 Apple XServe Raid Battery Replacement, Raid Battery: 手順 1、 2の画像 2
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: 手順 2、 1の画像 1
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: 手順 3、 1の画像 1
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: 手順 4、 3の画像 1 Apple XServe Raid Battery Replacement: 手順 4、 3の画像 2 Apple XServe Raid Battery Replacement: 手順 4、 3の画像 3
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: 手順 5、 1の画像 1
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: 手順 6、 2の画像 1 Apple XServe Raid Battery Replacement: 手順 6、 2の画像 2
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: 手順 7、 1の画像 1
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: 手順 8、 1の画像 1
    • Lift the raid card battery out of the chassis.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cody West
メンバー登録日: 10/20/20
234 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S14-G2, Cowan Fall 2020 Texas Tech, Team S14-G2, Cowan Fall 2020人のメンバー
TTU-COWAN-F20S14G2
1 メンバー
1のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 863
