メインコンテンツにスキップ
Apple Wireless Keyboard Logic Board Replacement
必要な工具と部品
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: 手順 1、 2の画像 1 Apple Wireless Keyboard Logic Board Replacement, Logic Board: 手順 1、 2の画像 2
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: 手順 2、 1の画像 1
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: 手順 3、 3の画像 1 Apple Wireless Keyboard Logic Board Replacement: 手順 3、 3の画像 2 Apple Wireless Keyboard Logic Board Replacement: 手順 3、 3の画像 3
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: 手順 4、 1の画像 1
    • Keeping the connection cable, push out the logic board's placement
  5. Apple Wireless Keyboard Logic Board Replacement: 手順 5、 1の画像 1
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: 手順 6、 1の画像 1
    • Remove the logic board from the placement
終わりに
20 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nicola
メンバー登録日: 11/14/13
638 ポイント
1ガイドが承認済み
9件のガイドコメント
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - 返信
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - 返信
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - 返信
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - 返信
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 17
過去 30 日: 92
今までの合計 50,051
