メインコンテンツにスキップ
Apple Wireless Keyboard Battery Replacement
必要な工具と部品
  1. Apple Wireless Keyboard Battery Replacement, Battery: 手順 1、 1の画像 1
    • Use a coin to remove the battery compartment cover.
  2. Apple Wireless Keyboard Battery Replacement: 手順 2、 2の画像 1 Apple Wireless Keyboard Battery Replacement: 手順 2、 2の画像 2
    • Slide the two (three on the previous generation) replacement AA batteries into the battery compartment. Verify the positive and negative terminals are facing the correct orientation.
終わりに
35 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
rab777hp
メンバー登録日: 11/17/09
20,333 ポイント
3のガイドは作成済み
チーム
OPEN OPEN人のメンバー
Community
82 メンバー
25のガイドは作成済み
5 件のコメント
This works great - as long as the batteries inside did not leak and create a permanent seal for the cap. I managed to get the keyboard working again by removing the batteries through the electronics compartment (remove grey center cover, slide electronics out). It did take some effort (including driving a screw into the stuck battery and yanking it out with pliers) to remove the stuck batteries and all the remains of the leakage, but I ended up with a working keyboard. Only thing is that I need to use the 'backdoor' every time my batteries need replacing, since the battery cover is permanently sealed...
Otto - 返信
Also have a perma sealed battery cover. Poured vinegar in from middle and let soak over night. Wanna drill into coin slot to try and remove cover but need to get batteries out first. Can I just remove the one screw from logic board and disconnect ribbon cable, to have it slide out the power button end? How careful w cable? Looks like it has 2 tiny clips, do these need to be addressed or can I just pry it off?
William Shouse -
Warm the area where battery screw cover is in a stream of hot water from the faucet. Be careful not to get water into the keyboard or keys. The warmth will sometimes expand the aluminum enough to loosen the screw cover. Worked for mine.
Greg M - 返信
Thanks!
worked well. Had to push old battery out from electronics cover area. Keyboard working again :)
tankapoet - 返信
It’s possible, but how can I get it? I am in somali country please help me
saalix49 - 返信
コメントを追加
統計データ:
過去 24時間: 18
過去 7 日: 109
過去 30 日: 523
今までの合計 98,026
