はじめに
Apple Watch Series 3 の接着剤を交換してデバイスを密封する方法ガイドです。
このガイドはGPSのみの標準モデルを対象としたガイドですが、Cellular /LTEモデルの方法も類似しています。重要な変更点はテキスト中に記載してあります。
必要な工具と部品
Apple Watchを上下逆にして、ディスプレイを平らなスペースの上に載せて、ケース側を持ち上げます。
ディスプレイの裏側に付着した接着剤の残りを綺麗に拭き取ります。
29 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
7 件のコメント
My adhesive gasket I ordered from you doesn’t not look like the one you use. I don’t see how it could work either.
My adhesive was larger than the rim so it had about 5-6 mm bump of extra plastic when I got it in the edge all around. Need it to be sealed so I didn't want to cut anything. Fail.
Kevin Male - 返信
Yes mine was also larger than the adhesive seal that is advertised here.
We believe this adhesive kit does not work all the time. there is still risk that with slightly water in-contact during activity, screen may slightly raised again. I think using glue E-8000 after wiping the edges of the watch with isopropyl is a good idea for long term safety.
iRepairMan - 返信
The Tesa adhesives that you sent are simply aweful. The cuts aren’t deep enough to safely remove the replacement adhesive with the blue protective film from the backing paper. Plus when you actually manage to do so, the adhesive’s dimensions are a bit short for the Series 3 42mm model.
