メインコンテンツにスキップ
Apple Watch Series 2 Battery Disconnection - prereq
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Apple Watch Series 2 Battery Disconnection - prereq, Power off your Apple Watch: 手順 1、 2の画像 1 Apple Watch Series 2 Battery Disconnection - prereq, Power off your Apple Watch: 手順 1、 2の画像 2
  2. Apple Watch Series 2 Battery Disconnection - prereq, Apply heat: 手順 2、 1の画像 1
    • Prepare an iOpener (or grab a hair dryer or heat gun) and heat the face of the watch until it's slightly too hot to touch.
    • Leave the iOpener on the watch for at least a minute to fully heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener, or move it around on the screen as sections cool, to heat the screen enough to pry it off.
  3. Apple Watch Series 2 Battery Disconnection - prereq, Observe all warnings: 手順 3、 3の画像 1 Apple Watch Series 2 Battery Disconnection - prereq, Observe all warnings: 手順 3、 3の画像 2 Apple Watch Series 2 Battery Disconnection - prereq, Observe all warnings: 手順 3、 3の画像 3
    この手順で使用する道具:
    Safety Glasses
    $3.19
    購入する
    • Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
    • Protect your fingers by keeping them completely clear of the knife. If in doubt, protect your free hand with a heavy glove, such as a leather shop glove or gardening glove.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
    • Feel free to attach or remove the watch band as needed to provide more control as you make repairs.
  4. Apple Watch Series 2 Battery Disconnection - prereq, Pry up the screen: 手順 4、 3の画像 1 Apple Watch Series 2 Battery Disconnection - prereq, Pry up the screen: 手順 4、 3の画像 2 Apple Watch Series 2 Battery Disconnection - prereq, Pry up the screen: 手順 4、 3の画像 3
    • Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
    • Press firmly straight down into the gap.
    • Once inserted, tilt the blade to pry the display open slightly.
    • Do not insert the knife more than 1/16th of an inch (~2 mm).
  5. Apple Watch Series 2 Battery Disconnection - prereq: 手順 5、 2の画像 1 Apple Watch Series 2 Battery Disconnection - prereq: 手順 5、 2の画像 2
    • Once you've opened a small gap with the curved blade, remove the blade and insert the thinner edge of an opening tool into the gap.
    • Push the opening tool into the gap, using your thumb as a pivot to lift the display open a bit farther.
    • Don't try to fully open or detach the display yet.
  6. Apple Watch Series 2 Battery Disconnection - prereq: 手順 6、 3の画像 1 Apple Watch Series 2 Battery Disconnection - prereq: 手順 6、 3の画像 2 Apple Watch Series 2 Battery Disconnection - prereq: 手順 6、 3の画像 3
    • Insert an opening pick under the display and carefully separate the Force Touch gasket from the display.
    • iFixit screen and battery repair kits include a replacement Force Touch gasket, so don't fret too much if yours is damaged.
    • Otherwise, to preserve the Force Touch gasket, pry carefully under the edge of the display. If the Force Touch gasket splits when lifting the display, or if you separate the gasket layers, you'll also need to replace the Force Touch gasket itself.
    • Slide the pick around the display to separate the adhesive between the Force Touch gasket and the display.
    • Don't insert the opening pick deeper than 1/16th of an inch (~2 mm).
  7. Apple Watch Series 2 Battery Disconnection - prereq: 手順 7、 3の画像 1 Apple Watch Series 2 Battery Disconnection - prereq: 手順 7、 3の画像 2 Apple Watch Series 2 Battery Disconnection - prereq: 手順 7、 3の画像 3
    • To avoid straining the display cables, don't open the display all the way yet.
    • Open the display to about a 45° angle, and use tweezers to peel off the adhesive between the display and the Force Touch gasket.
    • Thread the adhesive around and behind the display cables to get it off completely.
  8. Apple Watch Series 2 Battery Disconnection - prereq, Battery Disconnection: 手順 8、 2の画像 1 Apple Watch Series 2 Battery Disconnection - prereq, Battery Disconnection: 手順 8、 2の画像 2
    • Use a Y000 driver to remove the Tri-point screw securing the metal battery connector cover.
    • Remove the cover.
  9. Apple Watch Series 2 Battery Disconnection - prereq: 手順 9、 2の画像 1 Apple Watch Series 2 Battery Disconnection - prereq: 手順 9、 2の画像 2
    • Disconnect the battery by prying its connector straight up with the edge of a pry tool.
    • Bend the connector up slightly to make sure it does not make contact by accident.
終わりに
作成者
1人の作成者と共同作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,588 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,528のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 92
