メインコンテンツにスキップ
Apple Watch Series 2 スクリーンの交換
必要な工具と部品
ビデオの概要
  1. Apple Watch Series 2 スクリーンの交換, Apple Watchの電源を切る: 手順 1、 2の画像 1 Apple Watch Series 2 スクリーンの交換, Apple Watchの電源を切る: 手順 1、 2の画像 2
    • 作業の前にApple Watchの電源を切り、充電器から取り外してください。
    • タッチスクリーンが破損し、電源を切れない場合は、ここに示されている方法で電源を切ってください。
    Verify your model. The back of the Cellular model just says GPS, so be sure to check the groves where the watch band goes to determine you model. I made the mistake of just reading the back of the device and since I’d been gifted the device didn’t know it was cellular. Cellular has a different type of touch force gasket, different screen, and different battery connections.
    Ryan Holt - 返信
    From what I just read on Apple, the only differences in watch series 3 is 38mm and 42mm.
    mcr4u2 -
    As a consumer all you need to know are 38mm and 42mm
    Michael Adoga - 返信
    The back will say GPS LTE if it’s the cellular version. If it doesn’t say LTE it is only the GPS version. The displays are different whether or not it is LTE(cellular).
    themepark - 返信
    This alternative method only reboots the watch.
    Gregg Stanley - 返信
  2. Apple Watch Series 2 スクリーンの交換, 熱を当てます: 手順 2、 1の画像 1
    • iOpenerを使って、(もしくはヘアドライヤーかヒートガン)ディスプレイを温めます。触ると熱い程度まで温めてください。
    • iOpenerを少なくとも1分は載せて、スクリーンを十分に温めて、ケースに沿って留められた接着剤を柔らかくします。
    • iOpenerを再度温めるか、接着剤が冷却されないように、スクリーン周辺に動かしながら温め続けてください。
    I have heated up the iOpener to 165 degrees and left it on for more than a minute. No way I can lift the screen off with the exact knife. Tried different angles in various places, but no go. I also used a hair dryer un til the watch screen was too hot to touch and even tried a very hard cutting tool blade and also no go. Could n ever get the blade under the face I applied enough force where I could see that the blade left small marks, not very big, but could never get anything to move or lift. What am I doing wrong? I spent 47 years at a global computer company and I am used to taking apart small things and applying force when required. I don’t know what I am doing wrong. Please help me.
    Rafael Blanco - 返信
    Getting the initial gap is not easy. Maybe a playing card could work its way in the tiny gap and cut some adhesive. After that there might be some success with an exacto knife. Or you want to try a piece of aluminum foil (folded for more rigidity) for cutting the adhesive. Be aware of the force touch gasket and that it might get damaged during that procedure.
    Tobias Isakeit -
    I finally used a hot air gun set to 150 deg. C heating up the edges by slowly spinning the watch around before the technique worked. Difficult is the level noted and it’s correct. Finally worked and watch perfectly functioning.
    Chris Giavotto - 返信
    I used a heat gun, too. I was worried after reading comments that it would burn up the LCD, so I heated it a little bit at a time, rotating it like you did, and checking to see if I could get my knife under it. I must have hit one of the buttons because it did turn on, but that did reassure me that the display was okay.
    It's open. Now that the watch and I have had a few minutes to cool down, I'm ready for the next step. Not as difficult as I thought it could be. Tomorrow, I'll be replacing the battery in an iPod Touch 6th Gen.
    bester -
    I had to heat the iOpener 2 times and leave it on top of the watch for 10 minutes.
    Axel Trujillo - 返信
  3. Apple Watch Series 2 スクリーンの交換, あらゆる危険性に備えます: 手順 3、 3の画像 1 Apple Watch Series 2 スクリーンの交換, あらゆる危険性に備えます: 手順 3、 3の画像 2 Apple Watch Series 2 スクリーンの交換, あらゆる危険性に備えます: 手順 3、 3の画像 3
    この手順で使用する道具:
    Safety Glasses
    $3.19
    購入する
    • スクリーンとWatch本体の間の隙間は非常に狭いため、鋭利なブレードを使ってこの二つを乖離させなければなりません。作業を始める前に、次の注意書きをよく読んでください。
    • 作業中、ナイフから完全に指を離して指先を保護してください。不安な方は、ナイフを持っていない側の手をレザーグローブやガーデニング用グローブを着用してください。
    • 強いプレッシャーを本体に与えないようにご注意ください。ナイフがスリップしてしまい、怪我をしたりWatchにダメージを与えてしまうことになります。
    • 保護メガネを着用してください。ナイフもしくはガラスが割れてしまうと、破片が飛び散ることがあります。
    • Watch用ハンドの有無によってコントロール加減が変わる場合は、作業がやりやすい様に着用する、もしくは外してください。
    Don’t cut your finger off!
    Mike - 返信
    The Watch 3 stainless Steel has an additional Frame. Where do i have To Open it?
    asteffen@me.com - 返信
    I wore thick gardening gloves just to be safe 😅 and it took a while but the screen did come off.
    Axel Trujillo - 返信
  4. Apple Watch Series 2 スクリーンの交換, スクリーンをこじ開けます: 手順 4、 3の画像 1 Apple Watch Series 2 スクリーンの交換, スクリーンをこじ開けます: 手順 4、 3の画像 2 Apple Watch Series 2 スクリーンの交換, スクリーンをこじ開けます: 手順 4、 3の画像 3
    • カーブしたブレードをディスプレイとアウターケースの間の隙間の中に当てます。デジタルクラウンに一番近いディスプレイの短いサイドから初めます。
    • 隙間に向けてまっすぐ、しっかりと押し込みます。
    • 差し込んだら、ブレードの角度を傾けてディスプレイをわずかに開く様にこじ開けます。
    • ナイフ先端を2 mm以上、挿入しないでください。
    It’s difficult to grip case in a way that keeps fingers safe from the blade but doesn’t hit the side buttons and turn the device on!
    If it’s a struggle to get the display to release, warm case for a few more minutes.
    Kyle Powderly - 返信
    I have tried so may times to get the display to release but nothing works. Should have bought a new watch LOL. Kept the iOpener on 2 times for 10 minutes and it still won't open. There must be a better way.
    Susan E. White - 返信
    Hi Susan,
    if you're struggling to get the adhesive loose enough a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Dominik Schnabelrauch -
  5. Apple Watch Series 2 スクリーンの交換: 手順 5、 2の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 5、 2の画像 2
    • カーブした刃によって、小さな隙間ができたら、ナイフから開口ツールに持ち替えて、細い先端を隙間に挿入します。
    • 親指をコテにして、ディスプレイを少し持ち上げて開き、隙間に開口ツールを押し込みます。
    • ディスプレイを完全に開いたり、外したりしないでください。
  6. Apple Watch Series 2 スクリーンの交換: 手順 6、 3の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 6、 3の画像 2 Apple Watch Series 2 スクリーンの交換: 手順 6、 3の画像 3
    • 開口ピックをディスプレイの下に挿入し、Force Touchガスケットをディスプレイから慎重に取り外します。
    • 交換用Force Touchガスケットを含む、iFixitスクリーンとバッテリー用修理キットを販売しています。あなたのWatchに修理が必要でも大丈夫です。
    • もしくは、Force Touchガスケットを保存して再利用する場合は、ディスプレイ端の下を慎重にこじ開けてください。ディスプレイを持ち上げた際に、Force Touchガスケットが切断したり、ガスケットのレイヤーから外れてしまった時は、Force Touchガスケット自体も交換しなければなりません。
    • 開口ピックをディスプレイ周辺にスライドして、Force Touchガスケットとディスプレイ間に付けられた接着剤をはがします。
    • 開口ピックを2 mm以上、差し込まないでください。
  7. Apple Watch Series 2 スクリーンの交換: 手順 7、 3の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 7、 3の画像 2 Apple Watch Series 2 スクリーンの交換: 手順 7、 3の画像 3
    • ディスプレイケーブルを引っ張らないようにするには、ディスプレイを完全に開かないことです。
    • ディスプレイを約45度の角度で開き、ピンセットを使ってディスプレイとForce Touchガスケットの間の接着剤を慎重に剥がします。
    • ディスプレイケーブル周辺と裏に貼られた接着剤を綺麗に剥がします。
  8. Apple Watch Series 2 スクリーンの交換, バッテリーの接続を外す: 手順 8、 2の画像 1 Apple Watch Series 2 スクリーンの交換, バッテリーの接続を外す: 手順 8、 2の画像 2
    • Y000ドライバーを使って、メタル製バッテリーコネクタのカバーを固定している、トライポイントネジを外します。
    • カバーを取り出します。
  9. Apple Watch Series 2 スクリーンの交換: 手順 9、 2の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 9、 2の画像 2
    • 開口ツールの先端を使って、バッテリーのコネクタをまっすぐ持ち上げて、接続を外します。
    • アクシンデントでコネクタが接触しないように、コネクタを反対側に若干、折り曲げます。
  10. Apple Watch Series 2 スクリーンの交換, スクリーン: 手順 10、 2の画像 1 Apple Watch Series 2 スクリーンの交換, スクリーン: 手順 10、 2の画像 2
    • ピンセットを使って、ディスプレイケーブルコネクタを覆っているテープを剥がします。
    • テープ下側の右から作業を始め、ゆっくりに中央のコネクタ側に向けて、慎重に作業を進めてください。
    • テープの接着力が強力なことがあります。テープを強く引っ張ったり、ケーブルを破損させないように注意してください。必要に応じて、テープを温めたり、イソプロピルアルコールを使って接着剤を溶かしてください。
    Das Klebeband muss gar nicht vollständig abgelöst werden. Es reicht aus, die Stecker freizulegen. So hat man beim Wiederzusammensetzen das Klebeband wieder in der optimalen Position und auch nicht das Risiko, die leitende Folie zu verletzen.
    BMJ - 返信
    BMJ's comment translated by translate dot google dot com:
    "The adhesive tape does not need to be completely removed. It is enough to expose the connectors. This means that when you put it back together you have the adhesive tape in the optimal position again and there is no risk of damaging the conductive film."
    Robert - 返信
  11. Apple Watch Series 2 スクリーンの交換: 手順 11、 3の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 11、 3の画像 2 Apple Watch Series 2 スクリーンの交換: 手順 11、 3の画像 3
    • 一番左のコネクタには導電性ホイルが付いています。このホイルはテープを剥がす際に破れてしまうことがあります。
    • もしホイルが破けてしまった場合は、左下から摘んで、完全に取り除いてください。 この作業をすることで、ディスプレイ上の別のホイルにダメージを与えずにすみます。
    How important is the conductive tape?
    John Ellis - 返信
  12. Apple Watch Series 2 スクリーンの交換: 手順 12、 3の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 12、 3の画像 2 Apple Watch Series 2 スクリーンの交換: 手順 12、 3の画像 3
    • スパッジャー、もしくは整った爪を注意深く使い、ケーブルの反対にある小さなロッキングフラップをこじ開け、3本ある最初のZIFコネククターを解除します。
    Ir is viral to lift the small black flap or you ruin the entire process here, I lost everythign here...the first one stuck and the entire connector discintigrated on me, not my first rodeo, but lost the entire project.
    Lisa Russell - 返信
  13. Apple Watch Series 2 スクリーンの交換: 手順 13、 3の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 13、 3の画像 2 Apple Watch Series 2 スクリーンの交換: 手順 13、 3の画像 3
    • 残り2つのZIFコネクタ上の固定フラップを持ち上げます。
    • 交換用のスクリーンには、通常、固定フラップが閉じた状態で付いています。再組み立ての際、ケーブルを挿入する前にこのフラップを開いてください。閉じた状態では、Watchにダメージを与えてしまいます。
  14. Apple Watch Series 2 スクリーンの交換: 手順 14、 3の画像 1 Apple Watch Series 2 スクリーンの交換: 手順 14、 3の画像 2 Apple Watch Series 2 スクリーンの交換: 手順 14、 3の画像 3
    • ピンセットを使って、慎重にディスプレイ用フレックスケーブルを引き抜いて、接続を外します。
    • コネクタが外れない場合は、ゆっくりと引っ張りながら左から右へ揺らしてください。
  15. Apple Watch Series 2 スクリーンの交換: 手順 15、 1の画像 1
    • ディスプレイを取り出します。
    • Force Touchガスケットとその周辺に付ける接着剤を交換するための詳細な再組み立てのインストラクションは、ガイド終わりのリンク先ガイドを参照してください。
    hi
    how are you
    Please answer me quickly
    i have a apple watch 3 and broken lcd
    can i replace this lcd with a lost apple watch lcd?
    Does it work?
    I've heard that Apple does not allow this and ban the device!!!!
    Hossean Dad - 返信
終わりに
Force Touchセンサーの交換ガイドの手順10から続けて再接着し、修理を完了します。最良の結果を出すには、手順17が終わるまで新しいディスプレイを接続しないでください。
98 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
4人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
117,293 ポイント
188のガイドは作成済み
チーム
Master Techs Master Techs人のメンバー
Community
322 メンバー
2,521のガイドは作成済み
18 件のコメント
Job done….With a smashed screen remember to apply clear scotch tape to hold the screen together. Continue to heat the remaining stuck shards when the main bulk of the glass comes out. Pick them out carefully, and not to raise the gasket. Use a strong magnifying glass. the ifixit heat gel pack and tweezers helped me. Ensure that all tiny bits of glass have been removed form the body. Just turn it upside down, give a couple of gentle taps with something plastic. Pick out if necessary, taking care around the components. For a smashed screen, needs a good hour or more.
pep073 - 返信
Congratulations on the successful repair. And thanks for your comment and additional hints.
Tobias Isakeit -
This one was tough…and I’ve been doing various repair for years. Thank you iFixIt for top notch tutorials and instructions (and the progressive photos). I had a broken display and an iCloud locked watch for parts. Getting the display off the broken iWatch was easy…getting the replacement/good display off the other iWatch was very difficult. I keep at it and eventually it released, but I think I chipped the display edges slightly. If I have to do this one again, I may think twice. I’d say use plenty of heat. I used the iRemover, which helped a lot, it gets plenty hot and holds the heat for job. Once you’re inside, you’ll need that every so special 000 tri-lobe bit for the battery (for this I bought the iFixIt Pro toolkit…worth it to have a solidly made set of disassembly tools). I don’t think it’s worth breaking down the iWatch for repairs much further than the display or battery. The water resistant seal is compromised enough as it is with the display removal.
Erica Rogers - 返信
Just wondering are the ion x glass and sapphire crystal screens interchangeable because I have a broken series 2 aluminum case and it comes with the ion x glass but I want to get the sapphire crystal glass instead to make it stronger
Jacob Gerhart - 返信
Displays of the same Series, model and size should be compatible.
Tobias Isakeit -
Just noticed that my reply might come across a little vague.
Same Series hopefully makes sense (some swapped Series 3 onto Series 2 and vice versa which lead to the displays getting warmen than usually).
Same model means LTE or GPS which is probably irrelevant since the Series 2 does not have LTE.
And same size is hopefully a no-brainer ;)
So to summarize, yes, Sapphire display of the same watch should work instead of an ion-x.
Please let me know if it won’t work.
Tobias Isakeit -
I have an Apple Watch series 2 with wOS 5.2 and an iPhone 8 with iOS 12.3.1
After installing a new aftermarket display I’ve connected the watch with my phone with out any trouble. But I was not able to update to wOS 5.2.1 Also I added my credit card to wallet on the phone after the repair job, but was not able to add it to the watch.
So I tried to completely reset the watch and try it all again but now I am not able to connect it to my iPhone at all.
I have another Apple Watch 2 that has wOS 5.2.1 and a weak battery and a Digital Crown with ghosting behaviour but still the original display. Might it work to install the original display on the other watch to resolve the connection problems?
Has anybody made similar experiences and any idea/advice what I might do?
Kristian Heitkamp - 返信
I figured out, why the Apple Watch did not pair even though wOS 5 was installed.
I opened it and figured out, that the GPS modules connector was loose and just fell of the display, when I touched the cable.
Connecting the (broken) display from another watch made it pair and upgrade again but still I am not able to add Apple Pay. I guess that it recognises the GPS module and since it is wOS 5 it works even though it is not the original GPS module. But I think, because it is not properly connected to all three cables of the display the GPS maybe is not able to fix a location which disables the Apple Pay function out of security or licensing reasons.
Now I think this experiment confirms, that any display will work under wOS 5.2 (maybe even wOS 5), even if it is the display from another Apple Watch.
Hat super geklappt,
zwar wurde ich während der arbeit vom Hund erschrocken und habe somit den Force Touch Sensor etwas beschädigt; habe mich aber dazu entschieden einfach ohne ihn zu Leben. :)
Wirklich genutzt habe ich ihn nur für das löschen aller Benachrichtigungen.
Patrick - 返信
I’m curious about the following statement.
Continue from Step 10 of our Force Touch Sensor guide to re-seal your watch and complete your repair.For best results, don’t connect your new display until after Step 17.”
where is step 17? My up to date chrome browser is only showing 15 steps.
Other than that, I’m excited to fix my watch.
alexander perry - 返信
Hi alexander, that is step 17 in the Force Touch Gasket guide, not in this guide (which has only 15 steps). The Force Touch Gasket guide shows the steps with the display attached, but since you took it off during this guide you’re much better off attaching it after step 17. Have a successful repair
Tobias Isakeit -
Do i need to change the front screen with the lcd screen or can i change only the glass?
Cecilie Falch - 返信
Hi Cecilie, though it is possible to only change the glass, I’d not recommend it. You might feel the same after watching this video (it’s a Series 4 but basically the same procedure for the glass)—or you feel empowered by it and will try that procedure (with success hopefully): https://www.youtube.com/watch?v=PZYWzsB_...
Tobias Isakeit -
Si po montare un display serie 2 sul in serie 3? Grazie
vale rosi - 返信
it would be the same display of series 2 to series 3?
Abraham Mojica E. - 返信
Ich konnte vor dem Displaytausch mein ApplePay nicht mehr deaktivieren. Nun lässt sich mit dem neune Display keine ApplePay-Karte mehr hinzufügen. Gibt es hierzu eine Lösung?
Christian Ritter - 返信
Hello, good afternoon, if one applewach is locked, does the display still work for another applewach?
Polo - 返信
Yes, swapping the display from a locked watch to an unlocked watch should work. Only thing that could not work is the NFC / Apple Pay since the chip on the back of the display carries the NFC information and needs to be transferred.
Tobias Isakeit -
コメントを追加
統計データ:
過去 24時間: 24
過去 7 日: 174
過去 30 日: 569
今までの合計 120,363
