メインコンテンツにスキップ
Apple Watch Battery Replacement
必要な工具と部品
  1. Apple Watch Battery Replacement, iOpener Heating: 手順 1、 2の画像 1 Apple Watch Battery Replacement, iOpener Heating: 手順 1、 2の画像 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Apple Watch Battery Replacement: 手順 2、 1の画像 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Apple Watch Battery Replacement: 手順 3、 1の画像 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. Apple Watch Battery Replacement, Alternate iOpener heating method: 手順 4、 2の画像 1 Apple Watch Battery Replacement, Alternate iOpener heating method: 手順 4、 2の画像 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. Apple Watch Battery Replacement, Battery: 手順 5、 1の画像 1
    • Place the heated iOpener on the face of the watch.
    • Leave the iOpener on the watch for at least a minute to heat the screen and soften the adhesive holding it to the case.
    • You may need to reheat the iOpener, or move it around on the screen as sections cool, to heat the screen enough to pry it off.
  6. Apple Watch Battery Replacement: 手順 6、 1の画像 1
    • Because the gap between the screen and watch body is so thin, a sharp blade is required to separate the two. Read the following warnings carefully before proceeding.
    • Always keep your fingers completely clear of the knife.
    • Be careful not to apply too much pressure, as this might cause the knife to slip and cut you, or damage the watch.
    • Wear eye protection. The knife or glass may break, sending pieces flying.
  7. Apple Watch Battery Replacement: 手順 7、 3の画像 1 Apple Watch Battery Replacement: 手順 7、 3の画像 2 Apple Watch Battery Replacement: 手順 7、 3の画像 3
    • Using a curved blade minimizes the chance of scratching the case or cracking the glass. Only pry with the curved section of the blade, and not the tip or flat section.
    • Place the curved section of the blade in the gap between the glass and case on the lower edge of the watch face, and press firmly down into the gap.
    • Be very careful to maintain complete control over the knife—once the gap opens, if you're pressing too hard on the knife it may slip in and cut the battery.
    • This should wedge the gap open and cause the glass to lift slightly up from the case.
    • When the glass has lifted, gently rotate the knife down, opening the gap more by pushing the glass up.
  8. Apple Watch Battery Replacement: 手順 8、 3の画像 1 Apple Watch Battery Replacement: 手順 8、 3の画像 2 Apple Watch Battery Replacement: 手順 8、 3の画像 3
    • Once you've opened the gap enough, insert the tip of an opening pick under the glass.
    • Slide the pick along the bottom edge to separate adhesive holding the screen to the case.
    • Be careful not to insert the opening pick too far. Only about 1/8" ( about 3 mm) is necessary, any deeper and you may damage cables.
  9. Apple Watch Battery Replacement: 手順 9、 3の画像 1 Apple Watch Battery Replacement: 手順 9、 3の画像 2 Apple Watch Battery Replacement: 手順 9、 3の画像 3
    • Roll the opening pick up the side of the button side of the watch, gently pushing in to separate the adhesive and widening the gap as you go.
    • Remember not to push the pick in too far—it's easier to avoid this by rolling the pick, rather than dragging a tip along.
  10. Apple Watch Battery Replacement: 手順 10、 3の画像 1 Apple Watch Battery Replacement: 手順 10、 3の画像 2 Apple Watch Battery Replacement: 手順 10、 3の画像 3
    • Work the pick around the top right corner, and roll it along the top edge of the screen.
  11. Apple Watch Battery Replacement: 手順 11、 3の画像 1 Apple Watch Battery Replacement: 手順 11、 3の画像 2 Apple Watch Battery Replacement: 手順 11、 3の画像 3
    • Continue working the pick around the perimeter of the screen, rolling down along the left side to cut the last of the adhesive.
    • Leave the pick in place to keep the adhesive from resealing the screen in place.
  12. Apple Watch Battery Replacement: 手順 12、 3の画像 1 Apple Watch Battery Replacement: 手順 12、 3の画像 2 Apple Watch Battery Replacement: 手順 12、 3の画像 3
    • While holding the first pick in place, use a second to check that all of the adhesive is separated around the entire perimeter of the screen.
  13. Apple Watch Battery Replacement: 手順 13、 3の画像 1 Apple Watch Battery Replacement: 手順 13、 3の画像 2 Apple Watch Battery Replacement: 手順 13、 3の画像 3
    • There are two cables connecting the screen to the inside of the watch, near the top left corner. Be careful when prying or you may damage these cables.
    • Pry slightly up on the right side of the screen, to free it from any remaining adhesive.
    • Pry up on the left to free it as well—but do not attempt to remove the screen as it is still held in place by two cables.
  14. Apple Watch Battery Replacement: 手順 14、 3の画像 1 Apple Watch Battery Replacement: 手順 14、 3の画像 2 Apple Watch Battery Replacement: 手順 14、 3の画像 3
    • If you can see the top layer of your Force Touch sensor among the display adhesive, it means the two layers of the sensor separated and you're going to need to replace or repair it.
    • The top layer of the sensor may be adhered to the back of the screen—push it down to separate it, and switch to our Force Touch Sensor guide from this point on.
  15. Apple Watch Battery Replacement: 手順 15、 3の画像 1 Apple Watch Battery Replacement: 手順 15、 3の画像 2 Apple Watch Battery Replacement: 手順 15、 3の画像 3
    • Lift the screen up and shift it to the left, minding the display data and digitizer cables.
  16. Apple Watch Battery Replacement: 手順 16、 1の画像 1
    • Place the watch on an elevated surface, at least 1/2" or 1 cm tall—a small box or the edge of a book will work great. This will allow the screen to hang down vertically and give better access to the battery.
    • Be careful not to bump the screen or strain the cables while you work.
  17. Apple Watch Battery Replacement: 手順 17、 3の画像 1 Apple Watch Battery Replacement: 手順 17、 3の画像 2 Apple Watch Battery Replacement: 手順 17、 3の画像 3
    • Wedge a plastic opening tool between the right side of the battery and the case.
    • Pry the battery up to separate it from the adhesive securing it to the system board.
    • Do not attempt to remove the battery as it is still connected.
  18. Apple Watch Battery Replacement: 手順 18、 2の画像 1 Apple Watch Battery Replacement: 手順 18、 2の画像 2
    • Rotate the battery counterclockwise to expose its connector.
  19. Apple Watch Battery Replacement: 手順 19、 3の画像 1 Apple Watch Battery Replacement: 手順 19、 3の画像 2 Apple Watch Battery Replacement: 手順 19、 3の画像 3
    • Hold the battery up and out of the way, to expose the battery cable connector.
    • Use a plastic opening tool, prying against the bottom of the case to separate the battery cable connector from the watch's battery cable.
    • Remove the battery from the watch.
終わりに
To reassemble your device, follow our Apple Watchの接着剤の交換 guide.
361 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Optimus Goldheart
メンバー登録日: 10/17/09
502,656 ポイント
407のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,718のガイドは作成済み
30 件のコメント
I did a battery replacement in a 38mm Series 1 iwatch and the darn battery is not charging properly. It's been on the charger about 3 hours and I'm only at 14%. Any suggestions?
shableigh226 - 返信
I managed to replace a swollen battery ($33.25 on amazon) that popped the screen, but this is not for the faint of heart. Special emphasis needs to be placed on not twisting the digitizer connectors as they are quite fragile ($119.99 on ebay for a new digitizer). It's also easy to damage the force-touch sensor ($24.95 on iFixit). You also need adhesive gaskets ($12.98 for 5 on Amazon)
iFixit lists all the parts required but were out of stock on all but one of the items I needed at the time.
Battery:
https://www.amazon.com/gp/product/B01MV2...
Digitizer:
http://www.ebay.com/itm/262744629522?_tr...
Force Touch Sensor Gasket:
[リンクされた製品が存在しない、もしくは無効: IF308-013-2]
Adhesive Strips:
https://www.amazon.com/gp/product/B01N4J...
Charles Fulnecky - 返信
Appreciate the detailed steps, happy for the option but after reading the $79 to get Apple to replace vs the $33, plus tools for battery... taking it to Apple Store does not seem so bad.
fourydog - 返信
79 is just for battery …there Will be around 220$ service fees extra !!!
purnendra pratap singh -
Nope $79 complete. Just had it done at Apple store. Took about 30 minutes.
Albert -
コメントを追加
統計データ:
過去 24時間: 336
過去 7 日: 2,779
過去 30 日: 9,621
今までの合計 743,380
