メインコンテンツにスキップ
はじめに
A simple guide to replacing the optical drive in the external optical drive sold by Apple for the MacBook Air. If your optical drive breaks, use this guide to replace it.
Note: Here's a method to hack the OS X configuration file for the SuperDrive to be used on the older iMac, MacBook, or MacBook Pro systems that the drive normally won't work with. Use with caution!
Open the com.apple.Boot.plist file in a text editor or in terminal use nano you will see a key <key>Kernel Flags</key>
Under it add the following line:
<string>mbasd=1</string>
Reboot your Mac.
If you have the later model (produced after 2012):
You will unfortunately need to replace the internal drive from another identical Apple external SuperDrive, as the contacts on the PCB are soldered to the USB cable directly. The model produced prior to 2012 is a standard PATA slimline drive, but any SuperDrive purchased from Apple after 2012 will need a soldering iron to repair.
  1. To open the SuperDrive we must remove the lower case. The lower case is attached by 8 clips.
    • To open the SuperDrive we must remove the lower case.
    • The lower case is attached by 8 clips.
    • 6 along the sides
    • 2 on the back
    <<Add the following>>
    Note: Here's a method to hack the OS-X configuration file for the SuperDrive to be used on the older iMac, MacBook, or MacBook Pro systems that the drive normally won't work with. Use with caution!
    open the com.apple.Boot.plist file in a text editor or in terminal use nano you will see a key <key>Kernel Flags</key>
    under it add the following line
    reboot your Mac
    Dan - 返信
  2. Insert a metal spudger down between the black lower case and the aluminum upper case. Lightly pry back to gently lift the clip out of place, just far enough to disengage.
    • Insert a metal spudger down between the black lower case and the aluminum upper case.
    • Lightly pry back to gently lift the clip out of place, just far enough to disengage.
    • Don't lift to far, or the clip on opposite side of drive will be wedged in place.
  3. Repeat Step 2 for each of the 8 clips. Continue until all of the clips have been disengaged and the lower case is free.
    • Repeat Step 2 for each of the 8 clips.
    • Continue until all of the clips have been disengaged and the lower case is free.
  4. MacBook Battery 修理キット
    最低価格 $69.99
    Buy Now
    最低価格 $69.99
    Buy Now
  5. Lift off and set aside the lower case.
    • Lift off and set aside the lower case.
  6. Remove the screws holding optical drive in the upper case (A1270) three 3.8 mm with 1 mm deep head #00 Phillips head screws.
    • Remove the screws holding optical drive in the upper case
    • (A1270) three 3.8 mm with 1 mm deep head #00 Phillips head screws.
    • (A1379) 2 #00 Phillips head screws (I did not measure their length, sorry)
    • (A1379) 1 T9 torx screw
    On later models the bottom-right screw is a TR10 (Torx) screw.
    boelaars - 返信
  7. (A1270) Lift the optical drive from the thick side, then pull out. (A1379) You will need to be even more careful with this model, as there is less wiggle room. Peel back the insulation tape to see the connector.
    • (A1270) Lift the optical drive from the thick side, then pull out.
    • (A1379) You will need to be even more careful with this model, as there is less wiggle room. Peel back the insulation tape to see the connector.
    • Be careful of the wires still running from the drive to case.
    • When re-installing the optical drive insert tongue in groove side first, as pictured.
    On later models the cable goes left instead of right, after entering the enclosure. This makes lifting the optical drive harder, but if done carefully it can still be done safely. The cables and the tape that fixes it in place is flexible and sturdy enough.
    boelaars - 返信
  8. (A1270) Remove screws holding the board to optical drive. two 3.8 mm #00 Phillips head screws.
    • (A1270) Remove screws holding the board to optical drive.
    • two 3.8 mm #00 Phillips head screws.
    • (A1379) There are similar screws present here, but they only remove the metal shielding plate which gives further access to the USB wires
    • Unfortuantely, you cannot disconnect the drive any further without breaking out a soldering iron.
  9. Use a plastic opening tool to remove the  board from the optical drive. The optical drive is now free from the case.
    • Use a plastic opening tool to remove the board from the optical drive.
    • The optical drive is now free from the case.
まとめ
38 の人々がこのガイドを完成させました。
Alex Jansen
メンバー登録日: 2010年04月21日
8,428 ポイント
2のガイドは作成済み
After you pry open, inside there is an internal Super Drive.
Please tell me what's the markings/printed words model, name, brand, part number, etc....
Thank you.
gwen kent - 返信
My drive has nothing on that orange part in the middle of the drive (like you can see in the pictures here) except for two QR codes; it has absolutely no markings/printed words model, name, brand, part number, etc. on the inside, except the manufacturing date 2012 stamped inside the black aluminum bottom case cover.
Hope this helps.
cubanpete -
Thank you. My drive from 2012 ist fastened with a six-sided star-shaped Torx screw on the right side. The ones on the left side are black Philips screws and they are so tiny that they are hard to see in normal light. All I want to do is clean the drive from dust since it won't read DVDs anymore, while it has no problems with CDs at all. So now this Torx screw is another obstacle. I will have to waste more time & money buying an extra tool, thanks to Apple.
cubanpete - 返信
Is it possible to replace the internal DVD drive by a Bluray? Does macOS Sierra work with external Bluray drives?
Thanks for helping.
Sincerely
thomasli - 返信
Will any drive works? Is is SATA?
Philippe Morin - 返信
Nope, it's two different models- the first model was IDE, the second model has the USB cable soldered straight to the drive. Most unfortunate.
Josh Calvetti - 返信
Thanks Alex. If you want to clean the internals there are 4 screws holding the top of the drive. There is one a bit longer than the other three. Make sure you mark the hole for the longer one. Removing these screws and the top of the drive exposes all of the areas to be cleaned. Also, if anyone tinkers around with these and other computer devices even occasionally, it will make your tasks much easier if you buy the Ifixit Pro Tech Tool Kit.
Owen Gascoigne - 返信
Not sure why I wasn’t told till step 7 that I can not replace my optical drive because its soldered together. You can't just use another mac optical drive to replace it, they aren’t the same. Waste of time
Ryan Meyer - 返信
The guide does mention that there are two different versions in the introduction, and that if you have the newer version you’ll have to use an identical drive from another 2012 or later SuperDrive. It’s a stupid decision to be sure. Sorry it didn’t work out for you!
Josh Calvetti -
Does anyone have any information about the drive that I need for the soldered type drive. I can’t find out which drive to order. (part number or model number) I can find the earlier model drive, but not the newer drive.
kevs - 返信
Mine won't erase RW-DVD/CD and I was thinking in replacing the internals with a MacBook drive…
I probably will have it figured out before anyone answer but do they have the same interface?
Carlos Ferrari - 返信
コメントを追加する
統計データを表示:
過去 24時間: 4
過去 7 日: 51
過去 30 日: 247
今までの合計 59,514
