メインコンテンツにスキップ
Apple TimeCapsule A1355 opening for repair
  1. Apple TimeCapsule A1355 opening for repair, cutting the rubber: 手順 1、 3の画像 1 Apple TimeCapsule A1355 opening for repair, cutting the rubber: 手順 1、 3の画像 2 Apple TimeCapsule A1355 opening for repair, cutting the rubber: 手順 1、 3の画像 3
    • all measures are with the rubber still on. and it stays on.
    • first you take a cutter and cut little squared or circles or what you prefer into the rubber. and then, f.e with the screwdriver tear of the rubber on the incicion you just did.
    • there are exact measures in millimetres. I recommend to turn the TimeCapsule with connections facing you and then start from the lower left corner.
    • fyi: 1 inch = 25,4 mm, 1 feet = 304,8 mm
    • Note: the green lines indicate that the screws are in alignment with each other.
    • Note: the different color circles indicate screws. I found only the 1. gen TimeCapsule sometimes be having the purple screws. with the 2.,3.,4. Generation I never found the purple ones.
  2. Apple TimeCapsule A1355 opening for repair, different generations: 手順 2、 1の画像 1
    • the first generation is sometimes different. I had ones where in the purple markers are screws . sometimes they are reveted from the other side, and must not be removed.
    • the 2,3,4 generation have almost the same screws. sometimes the brown ones dont exist.
  3. Apple TimeCapsule A1355 opening for repair, opening the box: 手順 3、 1の画像 1
    • turn the TimeCapsile 90D clockwise.
    • then get something where you can lean on the opened but still connected part. (in my case I used another time capsule for it)
    • then carefully open the lid to the left. and carefully put it aside like shown on the picture
    • after that you can do inside whatever you desire. in my case I took out the hard drive
  4. Apple TimeCapsule A1355 opening for repair: 手順 4、 1の画像 1
    • if you are nerdy or have too much time on your hand, you can keep the cut-out rubber pieces and after replacement you can glue the right parts back in.
    • note: nobody sees the bottom of the TimeCapsule in general.
    • so I did not.
    • ENJOY
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Martin David
メンバー登録日: 05/27/13
244 ポイント
1ガイドが承認済み
チーム
LGBTQ Technicians LGBTQ Technicians人のメンバー
Community
15 メンバー
49のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 127
今までの合計 5,102
