メインコンテンツにスキップ
Apple Time Capsule Model A1302 Fan Replacement
必要な工具と部品
  1. Apple Time Capsule Model A1302 Fan Replacement, Remove the rubber base: 手順 1、 2の画像 1 Apple Time Capsule Model A1302 Fan Replacement, Remove the rubber base: 手順 1、 2の画像 2
    • Place a piece of cloth or a similar soft material on a clean, flat surface. Place the device upside down on top of the fabric.
    • Open the Time Capsule by exposing the screws that hold the device together. The screws are concealed by the rubber base, which is the bottom surface of the device.
    • Use a heat gun or hair dryer to heat the rubber base, which softens the adhesive holding it on.
    • Starting in a corner, carefully lift the rubber base to prevent tearing. You can use a guitar pick or a small, plastic ruler to help separate the rubber from the metal.
    • Take your time to prevent tearing the adhesive. Ensure that you don't overheat the device.
    • If you tear some of the adhesive, don't worry. The existing adhesive is more than enough to allow the rubber base to stick back onto the unit during reassembly.
    • During reassembly, you can apply heat to the rubber base. This will enable the adhesive to flow and form a better bond with the device's metal casing.
  2. Apple Time Capsule Model A1302 Fan Replacement, Remove the screws: 手順 2、 2の画像 1 Apple Time Capsule Model A1302 Fan Replacement, Remove the screws: 手順 2、 2の画像 2
    • Once the rubber base is separated from the device, remove the 8 Phillips PH00 screws that attach the metal bottom of the case to the plastic top of the case.
    • Use the Philiips #00 Screwdriver.
    • Some revisions of the Time Capsule have 10 screws. The A1254 revision has two screws in the upper right and lower left corners, as shown in the second image. In this situation, be sure to remove all 10 screws.
  3. Apple Time Capsule Model A1302 Fan Replacement, Open the Time Capsule: 手順 3、 2の画像 1 Apple Time Capsule Model A1302 Fan Replacement, Open the Time Capsule: 手順 3、 2の画像 2
    • Position the rear side of the device (the side with Ethernet connectors) so that it is facing you.
    • Lift up the left side of the metal plate and slowly flip it over the right edge of the device.
    • To prevent damage, do not lift the metal plate straight up or use force. As shown in the second picture, the fan is attached to the metal plate and connected to the logic board next to the power connector.
    • Since many people have had serious problems with the fan power connnector breaking, it is advisable to NOT try to disconnect the fan power connector. Be VERY careful with this connector. It is extremely fragile. If you absolutely have to disconnect the fan from the logic board, VERY carefully use a spudger or tweezers to do so.
  4. Apple Time Capsule Model A1302 Fan Replacement, Fan: 手順 4、 3の画像 1 Apple Time Capsule Model A1302 Fan Replacement, Fan: 手順 4、 3の画像 2 Apple Time Capsule Model A1302 Fan Replacement, Fan: 手順 4、 3の画像 3
    • These three plastic plugs hold the fan in place.
    • Use a plastic spudger or similar and press the plugs through the case to release the fan.
  5. Apple Time Capsule Model A1302 Fan Replacement: 手順 5、 2の画像 1 Apple Time Capsule Model A1302 Fan Replacement: 手順 5、 2の画像 2
    • To re-seat your fan use a spudger or similar to force the plastic plugs back in the way they came out. This can be fiddly, but after a few tries you master it.
    • If you are replacing your fan, make sure that the plastic plugs are included. Or be prepared to re-seat your fan using an alternative method like double sided tape or nuts and bolts.
終わりに
16 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
rousp
メンバー登録日: 02/18/10
6,658 ポイント
4のガイドは作成済み
4 件のコメント
would it be possible to remove the fan, or at least replace it with something quieter?
Tom Wiltshire - 返信
quieter maybe and adaptation now aa days can be possible, in the ballbearing ceramic espect is one , probably there are other ways to deal whit it…..because I think I know WHEN exectly you get irritated by that sound…..man, if I told you that Apple did all and much more bad decision according to the needs and capabilitys of the all equipment, there is why I &&^&^$^ angry about it, becuase when you get opened you will see the devil is in the details again…..lifatime determinied by this normal but fully controllable prooblem to resolev in name of there customers
Maurus -
there are significant emprovemtnes possible to the air flow doesn't acpmplish it mission that is RIP my product , I have done all changes I found since reoreantaded de cooler inlet outlet work as exemple , I'll try to bring this to here because these apple Timecapsluse were desing to fail due to overheat along the time, there are meny cases, incluisice at that time there was a page were you put the date that your time capsule were dead…
Maurus - 返信
I did change my fan according to this solution as it became louder every day.
Getting the fan was a bit of a search - I finally found and ordered it directly from an online shop in China.
When changing the fan the rubbers holding it are quite something to handle - you need a lot of tamper to make that happen.
Being very careful regarding the connector and it’s socket at least to me there was no difference to other connectors compared to eg. a 2013 iMac where I just changed the HDD and the RAM.
So if you are careful and don’t use at lot of force the connector shouldn’t be a problem.
I didn’t have to use a heat gun, the heat the old hard drive of my TC (which I also changed) was quite enough to peel the bottom layer of.
Thanks for this guide!
Florian - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 31
今までの合計 23,989
