メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Apple TV 4K Remote Battery/Charging Port Replacement
必要な工具と部品
  1. Apple TV 4K Remote Battery/Charging Port Replacement, Remote Battery, Charging Port: 手順 1、 1の画像 1
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 2、 2の画像 1 Apple TV 4K Remote Battery/Charging Port Replacement: 手順 2、 2の画像 2
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 3、 1の画像 1
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 4、 1の画像 1
    • Unlatch the connector that binds the touch screen and logic board.
  5. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 5、 1の画像 1
    • Use tweezers to pull off the connector that binds the touch screen to the logic board.
  6. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 6、 1の画像 1
    • Lift the face from the body of the remote.
  7. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 7、 2の画像 1 Apple TV 4K Remote Battery/Charging Port Replacement: 手順 7、 2の画像 2
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  8. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 8、 1の画像 1
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  9. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 9、 1の画像 1
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
  10. Apple TV 4K Remote Battery/Charging Port Replacement: 手順 10、 2の画像 1 Apple TV 4K Remote Battery/Charging Port Replacement: 手順 10、 2の画像 2
    • Gently dislodge the battery from the remote case, making sure to avoid damaging the battery itself.
    • The battery should be fully removed now.
終わりに
17 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Keenan Barber
メンバー登録日: 10/04/18
1,159 ポイント
3のガイドは作成済み
チーム
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G3
4 メンバー
15のガイドは作成済み
7 件のコメント
Great but can you explain how and what to use to seal it back.
With out sealing it not working properly
Thanks
Iva Sh - 返信
Hi there, where can you buy the actual battery replacement?… any links?
RLinhares - 返信
I second this. It would be great if someone could link us on where to buy the battery/charger replacement.
_ Dubb -
You won’t be able to source the original battery as it is spot welded to the lightning port cable and mobo cable, and is one unit. However if you can solder I have successfully replaced two remote batteries for about $6-$8 a battery.
sinkproductions -
I’ve searched high and low for this battery as mine will not maintain a charge for more than a few hours. I found this one for a Huawei watch: https://www.batteryclub.org/Goods/ECN106... that appears to be the correct specs, but I’m not sure it can be connected.
That noted, a new remote is only $52 and this battery is $39.50 plus shipping! So for my money a new remote is a better option since we know it will work, and it’s just $12 or so more! Nuts!
pgrobin - 返信
コメントを追加
統計データ:
過去 24時間: 47
過去 7 日: 360
過去 30 日: 1,464
今までの合計 81,346
