メインコンテンツにスキップ
Apple TV 4K Power Connector Replacement
必要な工具と部品
  1. Apple TV 4K Power Connector Replacement, Logic Board: 手順 1、 1の画像 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Power Connector Replacement: 手順 2、 2の画像 1 Apple TV 4K Power Connector Replacement: 手順 2、 2の画像 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Power Connector Replacement: 手順 3、 2の画像 1 Apple TV 4K Power Connector Replacement: 手順 3、 2の画像 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Power Connector Replacement: 手順 4、 1の画像 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Power Connector Replacement: 手順 5、 3の画像 1 Apple TV 4K Power Connector Replacement: 手順 5、 3の画像 2 Apple TV 4K Power Connector Replacement: 手順 5、 3の画像 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
  6. Apple TV 4K Power Connector Replacement, Power Connector: 手順 6、 3の画像 1 Apple TV 4K Power Connector Replacement, Power Connector: 手順 6、 3の画像 2 Apple TV 4K Power Connector Replacement, Power Connector: 手順 6、 3の画像 3
    • Use a T7 Torx to remove the screws:
    • Five 5mm screws
    • Carefully flip the device upside down to remove the logic board/power supply mount.
  7. Apple TV 4K Power Connector Replacement: 手順 7、 3の画像 1 Apple TV 4K Power Connector Replacement: 手順 7、 3の画像 2 Apple TV 4K Power Connector Replacement: 手順 7、 3の画像 3
    • Disconnect the latch connecting the power connector to the power supply.
    • Feed the wire though the logic board/power supply mount. After this, remove the power connector from the device.
終わりに
作成者
3人の作成者と共同で作成されました。
Brian Gehring
メンバー登録日: 10/04/18
451 ポイント
2のガイドは作成済み
チーム
UW Stout, Team S6-G3, Ogden Fall 2018 UW Stout, Team S6-G3, Ogden Fall 2018人のメンバー
UWSTOUT-OGDEN-F18S6G3
4 メンバー
15のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 48
今までの合計 2,810
