はじめに
This guide will show you how to properly get into your Apple TV 4K device and get access to the logic board for replacement.
パーツ
パーツは指定されていません。
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
6 の人々がこのガイドを完成させました。
7 件のコメント
Any idea on where I can purchase. new logic board?
Where do you buy the board…….
You’ll only be able to buy replacement boards on eBay or similar. I have successfully repaired a number of Apple TV 4K that had no power issues by fixing various shorted components.
Currently not possible to buy the board. But you can buy the power supply here. We have seen many problems with random restarting of apple TV 4K. Solution is to repair the board chip.
LagaiPhone - 返信
